**DATAZAP, '07 335i, FBO, MHD+, 93oct, 134k miles**
12-14-2020, 04:17 PM | #1 |
72
Rep 256
https://datazap.me/u/kazbek1/stage-2...0&data=3-21-25
2007 335i, FBO, MHD Stage 2+, original turbos, 134k miles Background: Everytime I stepped on it around 3rd or 4th gear, my engine light would come on with a 30ff code. I replaced both boost solenoids and all the vacuum lines about 5 months (1k miles) ago in an attempt to fix it. Purchased MHD about 3 weeks ago, logged a couple runs and was only hitting about 6 psi. Readjusted the chargepipe clamps which seemed to finally do the trick. I also have some nice WG rattle going on so I applied vacuum pressure to each WG through the boost solenoids. The front turbo held constant vacuum but the rear had a slow leak. I tightened the rear turbo's WG actuator rod (3 revolutions), retested it, and it held consistent pressure. Logged a few runs and was able to get about about 16-17psi. This last run I logged, I started in 3rd gear (around 40mph), floored it, and held it until I nearly redlined. That's when the engine light popped up again right as I was about to shift into 4th. The car didn't go into limp mode, just displayed the half-engine light (same as it did when I previously had the boost leak). A few things concern me while viewing this log: 1. I'm assuming I want cylinder timing corrections to be at 0 but it looks like the only one that does that is cylinder 3. What's going on here? 2. Rail pressure seems ok for the most part until the end when it drops as low as 463. What's the lowest it should normally drop to? How do I fix this issue? 3. I don't know where it should be but 'timing cyl 1 *crk' seems to be all over the place. Where should those values be and what's the remedy for that? Thanks in advance, everyone. Please let me know if there is anything else I should look into. Last edited by kazbek1; 12-14-2020 at 06:14 PM.. |
12-14-2020, 06:13 PM | #2 |
2001
Rep 3,731
When you logged your last run and got the half-engine symbol....what codes did it throw? It looks like you are getting timing corrections on all cylinders.
What MHD tune are you running? And what mods? |
12-14-2020, 06:19 PM | #3 | |
72
Rep 256
What are possible causes of timing corrections? What are the normal values I should be seeing? |
12-14-2020, 06:37 PM | #4 | |
973
Rep 3,219
I would look at replacing plugs and coils if you haven't done so recently first as they are cheaper. 30FF is a boost leak, worst case wastegates shot. Recommend following this guide... https://bmwtuning.co/bmw-n54-30ff-en...-repair-guide/ |
12-14-2020, 07:02 PM | #5 | |
72
Rep 256
Ive looked at that link like 100 times already lol I already did everything on there and am thinking it might just be time to replace my turbos. |
12-15-2020, 12:13 AM | #6 | |
973
Rep 3,219
If you've done everything and you still get 30FF code, yoir wastegates or turbos might be done for. Have you done a leak test? |
12-15-2020, 06:40 AM | #7 |
72
Rep 256
I haven't done one yet. That was going to be my next option but repositioning the chargpipe and adjusting the WG rod seemed to had done the trick. I guess not so I'll do a smoke test next. I do have a feeling it's the WG or turbos.
12-15-2020, 07:52 AM | #8 | |
973
Rep 3,219
Do another log and check, if its not then leak test, Stock turbos do go, but they usually last quite a while. |
