Do UK 335i's not suffer from the v29.2 lag?
10-14-2008, 03:40 PM | #1 |
145
Rep 898
Drives: F90 M5
My 335i is going in for some warranty work next Monday which I know will need the progman software to be updated.
The USA part of E90Post is up in arms about the latest software versions, claiming it introduces turbo lag and poor performance, but here in the UK forum no one seems to be mentioning it. Is this because it's not an issue in the UK? Has anyone got the latest software version on their 335i and is actually happy?
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
10-14-2008, 03:43 PM | #2 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
what is progman? you mean programe?
997.2 GT3
10-14-2008, 03:53 PM | #3 |
243
Rep 2,811
Drives: Jaguar XE P250 HSE
Progman software is the name given to the software in the ECU. Sometimes, some of the niggles are caused by bugs in the car's software and "re-flashing" the software with the most up to date version is done in the hope of fixing it (with your re-map, Carlos, flashing the software is a dirty word )
There seems to be a lot of versions of the software about and the Progman version referred to in the OP post is alleged to dis-improve the car. |
10-14-2008, 03:57 PM | #4 |
145
Rep 898
Drives: F90 M5
10-14-2008, 04:02 PM | #5 |
949
Rep 29,345
Drives: 997.2 GT3
cheers Alan.
I cant believe bmw would make the car less driveable due to an update. Those yanks are being paranoid surely.
997.2 GT3
10-14-2008, 04:03 PM | #6 |
136
Rep 1,954
Drives: 2020 X3M Competition
10-14-2008, 04:11 PM | #7 |
268
Rep 9,915
Drives: VW T5
10-14-2008, 05:48 PM | #8 |
Moderator
322
Rep 5,493
The V29.2 Progman update was designed to minimise, or at best eradicate, the rattling wastegate issue that was being experienced by quite a few 335i drivers. Essentially, what was happening was that at low revs the engine management closes the wastegates - however some wastegates suffered from a deterioration in freedom of movement, and therefore didn't close 100%. Because they weren't sealing properly, they were rattling away when the throttle moved from an open to fully closed position.
The solution BMW came up with was to reprogram the ECU so that it would keep the wastegates open until 3000 revs, therefore reducing the rattling. However, the downside to this is that the engine suffers from increased turbo lag at low revs, and hence the dispute in the USA started with drivers complaining that the V29.2 reduced the drivability and performance of the 335i. In practice, there is a noticeable increase in turbo lag with the V29.2 software (i had it on my car a few months ago, then changed back to V28.2 software because of this). BMW however realised that the software change did not fix the inherent wear problem with the wastegates, and so have recently issued an internal PUMA report to instruct dealers to replace the wastegates if there is sign of considerable rattling from the engine. The good news is that BMW are now on V31.1 Progman software, and I can report that the drivability is the same as that when I had V28.x. Bottom line - your car is going in for service and a software update - the software will be updated to V31.1, and you should have no problems or worries
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
10-15-2008, 12:47 AM | #9 | |
136
Rep 1,954
10-15-2008, 03:04 AM | #10 |
541
Rep 2,073
My car goes in today to be updated from 30.0.2 to 31.1, I have MDS81 as it's a July 08 build. I'll soon know for myself what 31.1 does. The dealer was so willing to load the new software that I'm optimistic the new version will be an improvement - I'll report back.
Current: G01 M40i Silver / Tartufo
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D |
10-15-2008, 03:33 AM | #11 | |
Moderator
322
Rep 5,493
We originally did an update from V28.2 to V29.2 to see the effect it would have on my car, no one liked it, so we reverted back and waited until V31.1 became available |
10-15-2008, 03:43 AM | #12 |
541
Rep 2,073
Which DME do you have? 80 or 81?
10-15-2008, 03:46 AM | #13 |
Moderator
322
Rep 5,493
MDS80. The same process/symptoms were displayed with MDS81 as well however.
10-15-2008, 09:06 AM | #14 | |
Rep 61
Drives: 2011 640d M Sports coupe'
How can you tell which version softwear you have load on you ECU? I have a march 2007 335i which has had turobs replaced due to actuators problems I belive software update was done first to see if the problem could be fixed, they had the car for over a week. |
10-15-2008, 09:08 AM | #15 |
541
Rep 2,073
Failure.....
When I got to the garage they wanted to diagnose etc. They can only update if there's a problem. Had I been reading forums....... They road tested the car, said it was fine. They are now going to research the problem via their own internal forum. I asked them to get a statement from BMW as to whether 1s to 1.5s of lag at low revs in 3r / 4th gear is acceptable, especially as when the engine is cold lag is less than 0.5s. The strange thing is that driving home the lag characteristic is now different, it's more linear, it is still there but somehow the curve has changed so it's less noticeable. I wonder if they reset the throttle adaptation. How do you do this on the E9x? I knew how to do it on my E4x.
10-15-2008, 10:10 AM | #16 |
Moderator
322
Rep 5,493
You can't tell which version of the ECU software your car has without hooking it up to a GT1 machine. When did your car get serviced?
10-15-2008, 10:19 AM | #17 | |
Moderator
322
Rep 5,493
If the dealer didn't keep your car overnight then they definitely haven't updated the software. However what they might have done is reset both the engine and gearbox adaptations via the GT1 machine. It is no longer possible to reset the adaptations yourself using the throttle pedal as we used to do on E46s. People who say otherwise are unfortunately misguided!
10-15-2008, 10:52 AM | #18 | |
541
Rep 2,073
10-15-2008, 11:03 AM | #19 | |
Moderator
322
Rep 5,493
The reset would certainly have helped.
The new software does reduce the effect of turbo lag. It isn't instantaneous response, but it is much better and now far smoother. Quote:
10-15-2008, 11:08 AM | #20 |
541
Rep 2,073
Was the fix definitely in 31.1? I have 30.0.2, is it possible that 31.1 isn't the fix but they've changed the adaptation?
10-15-2008, 01:10 PM | #21 | |
145
Rep 898
Drives: F90 M5
10-15-2008, 01:17 PM | #22 |
541
Rep 2,073
My dealer claims there's nothing in 31.1 to fix any lag or wastegate problems. Somehow we have to get to the bottom of this.
