Powersteering reservoir cap always wet?
12-12-2020, 07:41 AM | #1 |
2001
Rep 3,731
I've noticed on my 07' 335i that even if I clean it off really well, after a few days of driving there powersteering fluid cap starts to get wet around the outside. Eventually, if I don't wipe it off again, the whole cap will get covered in fluid residue and dirt and grime.
Is there a seal that's bad? Or does the plastic cap or reservoir warp over time? It's not a huge issue...I'm just getting tired of cleaning the stupid thing off all the time.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
12-12-2020, 08:55 AM | #2 |
4276
Rep 9,206
It’s overfilled. I don’t get this even on my track E90 335i where the steering endure a lot of hard work. I check level only with engine running and when power steering fluid is hot.
12-12-2020, 09:25 AM | #3 | |
1044
Rep 1,667
Wolf 3352340.50 |
12-12-2020, 11:21 AM | #4 |
700
Rep 1,227
I had the same issue on my 330i and would constantly have the level become too low by spilling its guts out over time. Turns out the breather hole that the cap had a bunch of gunk in it. My laws of fluid dynamics as the fluid became hotter it would siphon itself up thru the hold and spill out.
I took a pipe cleaner and ran it up and down from the bottom then in and out and cleaned out with brake cleaner as well. Ever since it was cleaned the "sweating" has stopped and will actually keep the level correct. |
12-12-2020, 04:57 PM | #5 |
2001
Rep 3,731
12-12-2020, 04:59 PM | #6 | |
2001
Rep 3,731
12-12-2020, 05:19 PM | #7 |
865
Rep 5,450
Get a new o-ring for the cap, they all weep after 10 years, usually the oring will take care of it.
https://www.fcpeuro.com/products/bmw...al-32411128333
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
12-12-2020, 08:53 PM | #8 | ||
4276
Rep 9,206
12-12-2020, 09:48 PM | #9 |
2341
Rep 3,539
I has the same issue at one point. Good cleaning and seal replacement on the cap fixed it.
12-18-2020, 10:51 AM | #11 | |
26
Rep 171
It's like $15 or so Pick up some other parts while you're at it to get free shipping, lifetime warranty on everything anyways |
12-18-2020, 05:38 PM | #12 | |
865
Rep 5,450
feuer4275.50 |
