12-09-2020, 09:06 AM | #1 |
248
Rep 354
N55 Stage2 BM3, intercooler required?
I recently went stage 2 on my M2 vrsf catless DP BM3. When flashing it said that intercooler is required for Stg2 witch I am not running will I have any issue when the weather gets a little warmer?
12-09-2020, 09:21 AM | #2 | |
2429
Rep 2,526
nioh_lbbm21716.50 gphung193.50 |
12-09-2020, 09:29 AM | #3 |
6637
Rep 4,145
Drives: '18 M2 6MT
Yes, IC is required for Stage 2.
12-09-2020, 09:32 AM | #4 |
248
Rep 354
12-09-2020, 09:46 AM | #5 |
2429
Rep 2,526
12-09-2020, 11:43 AM | #7 |
#gotboost
517
Rep 861
The stock intercooler doesn't even keep up on a stock car
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
12-11-2020, 12:05 PM | #8 | |
5865
Rep 6,636
The stock intercooler sucked with the stock tune. Temperatures increase quick on that thing and power is pulled when temps are high. Don't think it will take long for you to feel reduced power on stage 2 tune with stock IC. You're going to be making less power than stock maybe after one pull because the temps will be so high the car ecu will pull all the power until it cools off. Don't believe me? You have BM3 take some logs and see for yourself what happens to IAT temps after one decent pull. Then do another and watch timing. |
VisualEcho6636.50 JoshuaevansF87247.50 |
12-11-2020, 01:13 PM | #9 | |
6637
Rep 4,145
Drives: '18 M2 6MT
Even on a stock car you should replace the IC and charge pipe at a bare minimum. |
///M TOWN16566.50 chief1richard381.00 |
12-11-2020, 04:55 PM | #10 | ||
248
Rep 354
12-20-2020, 11:01 AM | #12 |
Life is on the Track, the rest is just waiting.
381
Rep 731
What hp gains did you get with your stage 1. Was it a noticable bump. My warranty will be expiring soon and it may be on my list of mods.
At a Point above 7,000 RPM.
12-20-2020, 11:10 AM | #13 |
381
Rep 731
Stock Intercooler
If I remember correctly, The M2 stock intercooler is one used from all prior models that had a turbo engine. They did not make one specific to the M2. When you take it out you will see how cheap it is. Not fitting for an M model.
AnthraciteOG398.00 |
12-21-2020, 03:15 AM | #14 | |
279
Rep 488
I didn't, but someone in the UK shared the attached map with me prior to me buying my license. The chart only tells so much; the stock hardware is not really capable of running a tune - sure the above looks ok on a single dyno blast, but the IATs rise rapidly and within a couple of runs through the revs down a county lane, the car starts losing power due to heat soak. Also, IMO, the stock tune was nicer to drive, with more of a rush to the redline and much less tendency to immediately overheat. The later BMW tunes (assuming you have a recent ISTEP) were actually very good. TBH, at that time, if I could have backed out the tune I would have returned to stock (but switching to the "stock" BM3 map is not the same - I think that it is a copy of an early BMW tune, but BMW made big improvements themselves on the stock tune over time). Therefore, TIP, if you do tune, backup your ECU first. This is not a knock against PTF's work, but just the reality faced by such a crap intercooler being on the car from the factory. Originally, I had no plans to do Stage 1, but I knew that that I was going to go to do Stage 2 eventually, and a BM3 license popped up at a price I couldn't let pass on. TBH, doing Stage 1 just accelerated the rate I moved to Stage 2. Stage 2 is another thing altogether though, and absolutely worth it! My car is putting down 431bhp (crank) and has a power to weight ratio of 288bhp/tonne - that is super quick! My recommendation: Don't do stage 1 in isolation, at least do it with an intercooler. (The only trouble is that once you have done that is that you are only 1K away from stage 2, so most just skip stage 1) WT |
