Bosch sparks plugs : ZGR6STE2 vs ZR5TPP33 vs ZR5TPP33S
12-04-2020, 04:51 AM | #1 |
201
Rep 713
Hello,
I may change my spark plugs, it has been changed (with coils) 10.000 miles ago, but i ran sometimes for extended periods (like many months) some octane booster bottle in the past and it's known that it can foul plugs and made them orange. I have a small problem at low rpm (made another thread about that), so i want to exclude a spark plug problem by replacing them. I want to stay Bosch, and on auto parts website i go, for my specific vehicle (N54) (based on plate search) i indicates that for Bosch, i have three choices : ZGR6STE2 : 9$ cheapest in price, the OEM ones, that i have now in my car (some claims that the OE one from BMW dealer, stamped BMW are better and are a bit different) ZR5TPP33 : 9.50$ supposed to fit my N54, but originally designed for N55, and 1-step colder than N54 ZGR6STE2. ZR5TPP33S : 15$ same as above, but better quality/internals ? Two questions here : Since my car is FBO : (DP, FMIC, CP, MHD Stage 2+), is it good choice to go the ZR5TPP33/ZR5TPP33S choice that is 1-step colder or should i stick to the first choice ZGR6STE2 ? If N55 plugs are good/better for N54, does it come already gapped to correct specs ? I am asking cause i didn't find a lot of people experiencing the n55 plugs on a n54 engine.
beter laat dan nooit
12-04-2020, 10:04 AM | #2 | |
393
Rep 972
I think it's a good choice to stay with Bosch plugs, I have never been a fan of NGK. I have always used these and they have never steered me wrong....They claim the heat range is fine up to 475 hp. https://burgertuning.com/collections...n54-spark-plug
Instagram : @Bimmer_bro
12-04-2020, 10:25 AM | #3 | |
201
Rep 713
I only tested the OEM Bosch like you, ZGR6STE2. (But i didn't bought them stamped Bosch-BMW at the BMW dealer (higher price), i got the Bosch online too) That said, the two other plug i speak about in this post are OEM Bosch too, not NGK. It's just that it's N55 plugs, and my auto parts website (well known) list them as compatible with N54. Let's say i am not researching and buy the higher price ones, i would imagine that it's compatible without gapping, i would find weird that the shop won't tell it need gapping or something, but you never know Since it's approximatively the same price for the second one, i wondered if it's worth the "upgrade" if it's one, or if it's maybe worst... I am on 91oct stage 2+, and maybe it's safer to stick with the original one anyway. Just curious to know if one tested thoses N55 plugs on a N54.
12-04-2020, 11:22 AM | #4 | ||
393
Rep 972
The gap on the Bosch 3 prong plug cannot be changed away.
12-04-2020, 04:08 PM | #5 | |
201
Rep 713
It seems no one have any clue about the N55 spark plugs... it's maybe good or not, but hard to find out cause nobody have some infos on them.
12-04-2020, 09:13 PM | #7 |
201
Rep 713
yep Tyc0 i am running more boost than stock because stage 2+, but i prefer to run stock spark plugs then, i don't want to have to rule with the gap thing.....
in this thread i just wanted to know if the bosch 1-step colder n55 plugs need gapping or not...
12-04-2020, 09:22 PM | #8 |
147
Rep 517
I believe any spark plug will need gapping at higher boost levels, I believe the gap is 22 thousands. But you could always put them in and see if the boost blows out the spark or not. Worst case you get a misfire and have to gap them, which is extremely easy.
12-04-2020, 09:48 PM | #9 |
201
Rep 713
Yep, you are right, in every thread i read, they speak about 0.022 gap or something but you can't gap the first one i talk about, because it has 3 dents or something, the two other can be gapped, i just wonder if it came already gapped or not (and it's one step colder than the first one).
12-04-2020, 09:51 PM | #10 | |
147
Rep 517
12-05-2020, 05:02 AM | #11 | ||
4276
Rep 9,206
335e92tx1036.00 |
12-05-2020, 05:33 AM | #12 | |
201
Rep 713
nobody here seems to have tested these n55 plugs on the n54, so i will probably stick with the first ones anyway it's safer i guess
12-05-2020, 08:28 AM | #13 | |
4276
Rep 9,206
12-10-2020, 08:00 PM | #14 | |||
147
Rep 517
12-24-2020, 06:29 PM | #15 | |
ahat
1036
Rep 2,592
From RSL a while back - https://www.e90post.com/forums/showp...postcount=2809
these are thinwire bosch https://www.ecstuning.com/b-bosch-pa...2120039634kt2/ Quote:
Enjoy the life in canada bro. It wont work in TX And 94 in .ca is not common.. normally the 92 is sucky.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 12-24-2020 at 06:40 PM.. |
12-24-2020, 09:57 PM | #16 | ||
393
Rep 972
I'm glad we have some 94 around but I'm not sure how great it is... although the butt dyno does feel nicer on the 93 map vs the 91.
335e92tx1036.00 |
