FBO E92 335i, wastegate rattle?
12-03-2020, 12:17 AM | #1 |
Rep 7
This is a cold start. I'll try to get a sound recording while revving the car in neutral. When revving in neutral I get the impression it's the wastegates because I hear rattling after the revs drop. Am I going paranoid?
No performance loss or fault codes. I searched around a bit and some people say it's normal to have some wastegate rattle but mine seems to be pretty audible in tunnels as well, bouncing off against walls between 1500-2000rpm. I should note that I have catless downpipes and a full Akrapovic exhaust so I only have a muffler. https://drive.google.com/file/d/10ZF...ew?usp=sharing Some others that sound like mine: Last edited by trenbalonace; 12-03-2020 at 12:31 AM.. |
12-03-2020, 09:42 AM | #2 | |
393
Rep 972
Instagram : @Bimmer_bro
12-03-2020, 10:59 AM | #3 |
2001
Rep 3,731
Adjust the wastegate rods.........that will get rid of the rattle. Search google, plenty of I do and videos on how to do it. Rear one is pretty easy, from one takes a little time but not horrible...you actually use a washer to space out the actuator on the front turbo since you can't easily adjust the rod.
Jaronbwall284.50 |
12-03-2020, 01:40 PM | #4 | |
Rep 7
Can't believe it requires entirely new turbos to get rid of it. |
12-03-2020, 01:54 PM | #5 | ||
393
Rep 972
Unfortunately the oem wastegates are a poor design and they can not be replaced without the turbos being replaced. If you do decide to go this route, check out the RB turbos with upgraded wastegates. Obviously this is an expensive fix so I would explore those diy methods first.
12-03-2020, 02:06 PM | #6 | |
2001
Rep 3,731
https://www.fcpeuro.com/products/bmw...waAqXgEALw_wcB
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
12-03-2020, 02:09 PM | #7 | ||
393
Rep 972
12-03-2020, 02:11 PM | #8 |
329
Rep 603
I've seen another "fix" on the BMW doctor channel.
I'm not 100, but I'm pretty sure your going to need to remove the front turbo in order to get that FCP kit on. Not sure you can access what you need to with the front turbo still in the car. Someone more knowledgeable then myself will surely verify that nugget. |
12-03-2020, 03:13 PM | #10 |
329
Rep 603
I didn't look at that FCP kit closely enough to notice that it has actual replacement waste gates. Duh, my bad. Of course they have to come out of the car and be totally opened up.
The other "fix" I had seen was some sort of apparatus that attached to the arm that actuates the waste gate and somehow provided tension to keep them closed and rattle free. |
12-03-2020, 06:51 PM | #11 | |
973
Rep 3,219
Can you post a warm start and rev it? Mine was pretty bad, was hearing the rattle accelerating, so had the wastegates upgraded with Incolnel ones at a garage years back. Had I known that RB turbos, I would have just got the OEM ones with upgraded Wastegates |
