Help Me understand fuel trims STFT logs inside
11-21-2020, 03:21 AM | #1 |
10
Rep 106
Mods FBO + inlets outlets stage 2 turbos, stage 2 lpfp E45 Can someone take a look at this log and tell me if it looks okay. I was tuned 2 years ago just to make sure things are still good. Running E45 fuel trims go negative -15 are those numbers ok? Thank you in advance https://datazap.me/u/azizzlol/log-16...51-159-156-146 |
11-21-2020, 09:16 AM | #2 |
262
Rep 818
You are far away from the right category..
From the little details in your log everything looks good except for one instance where you from went positive.. I am not sure what happened there but you went lean all of the sudden.. . Your short term fuel trims should stay under 30% one way or the other. The difference between the two should be below 10% variance.. And its better to be in the negative then positive.. Negative is taking away fuel which means you are running on the rich side and car is correcting.. Positive is running lean and car is adding more fuel to richen mixture.. Do you know why you went lean? Maybe let off gas? |
11-21-2020, 02:27 PM | #3 | |
10
Rep 106
I will do my research more on STFTs looking at other people's logs got me worried, running -15 or -20% stft is pretty normal on my e50 tune right? And also there's some timing pulls about 3-4 degree. I shouldn't be worries much? Btw car has new plugs gapped 0.022, new coils, new hpfp. |
11-21-2020, 06:42 PM | #4 |
772
Rep 1,418
Your LPFP is sort of struggling. Might want to look into larger lines or new FPR.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
11-21-2020, 11:44 PM | #5 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Wrong section lol
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
11-22-2020, 01:06 AM | #6 |
26
Rep 171
Use the link down below, takes you to the right part of the forum to ask this question
Avoid using marketplace for suggestions Wish ya the best in finding your problem https://www.e90post.com/forums/forumdisplay.php?f=58 |
