Replacing turbos-What else to do while in there?
11-16-2020, 08:23 PM | #1 |
101
Rep 304
Hey everyone. My turbos finally let loose,and I have a set of pure 600's on order. Since my them for this car is "while i am in there", i want to go ahead and take care of any other bullshit i might encounter or need to take care of at some point...
I already have inlets on order as well as they are required for the turbos. I ordered a new RB Turbo PCV valve as well, and good thing too as my valve cover gasket just let loose this week as well... Is there anything else I should look at doing while I am in there? For reference, I have already done: -New motor mounts -m3 control arms -entire cooling system in less then 100 miles -intercooler -charge pipe -catch can I don't think (hoping) there is much else to do, but was hoping for feedback in case I am missing something. Just want to be done with all the maintenance, lol. |
11-16-2020, 11:14 PM | #3 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Here come the rod bearing guys.....
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
11-17-2020, 11:22 AM | #5 |
63
Rep 124
oil pan gasket/oil level sensor o-ring
upper o2 sensors Rod bearings if you don't mind a few hours of extra work. They aren't hard to do.
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
11-17-2020, 06:05 PM | #10 |
67
Rep 128
IllSic_Design2124.00 |
11-17-2020, 06:06 PM | #11 |
67
Rep 128
11-18-2020, 10:26 AM | #12 |
101
Rep 304
11-18-2020, 12:00 PM | #13 | |
67
Rep 128
These engines have bearing issues. Period. Denial by part of the community doesn’t change that aspect. I’ve personally done bearings on multiple n54s. They all have shown wear. Here’s a bearing I pulled from a auto xdrive with 100k. Stock turbos. Well maintained. https://www.e90post.com/forums/showthread.php?t=1737521 You’re rolling the dice if you don’t look into it imo. Would be a shitty thing to end up with rod knock and to destroy those new turbos with metal shavings. I did the bearings on my 6062 car about 10k ago. I bounce it off rev limiter more than I should, and I’ve had no issues since reassembly. |
11-18-2020, 12:04 PM | #14 |
2685
Rep 4,202
I've never said yay or nay one way or the other on rod bearings, I just like fuckin with yall at this point
11-18-2020, 12:23 PM | #15 |
67
Rep 128
11-18-2020, 02:42 PM | #17 |
298
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
I did my oil pan gasket, it was leaking like a bitch. Other than that, new engine mounts, and all oil and water lines from turbo's...you don't want to go there again for one of them leaking. Dropping that heavy subframe is no fun.
11-18-2020, 03:07 PM | #18 |
101
Rep 304
That was actually going to be the next thing i thought of. I really don't want to spend any more money then I have,but i'm thinking i may be wanting to replace those as well. My car has been a florida car all it's life, so no real rust/corrosion concerns, but wasn't sure how flimsy the oem units can be.
11-18-2020, 04:01 PM | #19 | |
298
Rep 650
It became a 3 weeks exercise (with all the oil pan , reassembly all up, etc). Anything I do on this car, if I haven't touched it before, it's a cutting with Dremel exercise... |
haaken675101.00 |
