11-16-2020, 01:51 PM | #1 |
Cheapskate
4450
Rep 4,995
Options to make power without E85
I made a video explaining why E85 is so important on our cars, and how you can increase your HP if you don't have E85 available at the pump. Hope this helps.
11-17-2020, 04:59 AM | #6 |
395
Rep 1,010
Thanks for taking the time to make this helpful video for those of us who don't have access to Ethanol or even reasonable octane gasoline.
Only problem I've yet to see somebody confirming the power gains from a bigger turbo running on Gasoline only. Are those gains worth the $XXX of the bigger turbo and also sacrificing some low rpm extra spooling time ? Also why didn't you mention your CSF heat exchanger, shouldn't it also help with lower IATs and slightly improve power ? Thanks mate.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 11-17-2020 at 06:25 AM.. |
11-17-2020, 07:22 AM | #7 |
189
Rep 282
i like the video , but i have also one question , what if you would mix toluene into the fuel ? it has an octane value of 120 i believe . also higher energy content compared to ethanol , but its nastier
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
11-17-2020, 08:29 AM | #8 | ||
Cheapskate
4450
Rep 4,995
And here are comments from Peter @ Pure EU on their Pure800 on their pump gas development. Quote:
Not familiar with that one. I'd stick with what's readily available and tested. |
IMS-340C394.50 |
11-17-2020, 09:34 AM | #9 |
112
Rep 216
Boostane or racegas are nice alternatives to give a solid octane boost for those without e85 if it wasn't mentioned. (I'll watch the video when not at work)
11-18-2020, 07:41 AM | #10 |
BimmerPost Supporting Vendor
24286
Rep 190,975
Thank you for the video
kern4174449.50 |
11-18-2020, 11:49 AM | #11 |
Cheapskate
4450
Rep 4,995
I didn't mention it because some people have adverse affects. It might be something you can use from time to time, but I don't recommend long term use.
11-18-2020, 10:05 PM | #12 |
316
Rep 420
My opinion: a methanol feed unit is a universal remedy. You can use it only when necessary and it is easy to create your own firmware for it with JB4. At 98/100 / 102Ron, methanol will give an additional 35 / 85whp, depending on your turbine type. Stoke or hybrid turbo. I was able to squeeze out of the GC 626whp using WMI at 100Ron + 30% E85. And 520whp on a simple 100Ron. And 580WHP on 100Ron + WMI.
M140IX. Turbo Pure 800 Cast.
kern4174449.50 |
11-19-2020, 12:38 PM | #13 | |
Cheapskate
4450
Rep 4,995
