F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > 480AB5 Transfer Case Long-Term Protection Funcion
Extreme Powerhouse
      11-12-2020, 03:06 PM   #1
bendeyo
Drives: 2013 BMW F30 N55 335XI
Hoping someone can tell me if this is a true concerning error or not? I have this transfer case error coming up under info memory and I'm unable to clear it. It's been listed for about 6 months. Do I just need to have the fluid replaced in my transfer case? I typically do all the work myself but this looks to be a ridiculous job based on the location of the drain plug.
2013 335xi F30
JB4 Map 5
110,000 miles
Info memory
Dynamic Stability Control
480AB5: TRANSFER CASE LONG-TERM PROTECTION FUNCTION REQUESTED BY
THE LMV
      12-06-2020, 05:30 PM   #2
Charles B
Charles B
Charles B's Avatar
Drives: 335 M235 Z4 944 Turbo
2013 BMW 335  [9.17]
2016 BMW Z4  [10.00]
1986 Porsche 944 Turbo  [0.00]
I've replaced my transfer case fluid. Really it was not bad at all. I took some brake line and bent it, snaked it through the fill plug, attached it to syphon pump (Mighty Vac) and got all the fluid out.
      12-14-2020, 03:03 PM   #3
brigade24
brigade24's Avatar
156
Drives: 2013 335 X-dive
i removed the transfer case and actually drained it out the breather tube like the book said...It wasn't that bad, but my goodness what were they thinking...60k car with no drain plugs for the rear diff or transfer case...WTF
      12-31-2020, 11:55 PM   #4
kerny7678
High Miler
Drives: 2015 328xi Mineral White
Did you get the fluid changed out?
I did mine the other day. Simple job.
CTK
      04-16-2021, 12:01 PM   #5
Sedds
F30 Noob
Drives: 2017 BMW 340ix
2013 335xi F30
JB4 Map 5
110,000 miles
Info memory
THE LMV
Anyone ever get info on this or what's causing the code to trigger? I just got Bimmerlink and cleared all the bogus codes my 2017 340 x drive was throwing. This code remains and Bimmerlink says it is unable to remove the code.
No permanent codes/errors, just this single code showing up in Info Memory that will not go away.
FWIW, I purchased the car CPO back in November with 30k miles on the nose. I'm pretty close to hitting 35K right now. At about 32,500 I very luckily noticed a fluid leak in my driveway by chance. Wasn't even looking for it because I figured the car is so new why would it be leaking. I diagnosed it as a front diff leak and took it in. O ring and bolt on the front diff were replaced under warranty and new fluid was added.
Related/unrelated? I'm covered with CPO until May 2022, but I've read a lot of issues with people having front diffs, rear diffs, and TC replaced on these cars. Would like to get it all sorted before losing the warranty.
Thanks for any help/info.
      05-01-2021, 06:50 PM   #6
Whatsupguy
Whatsupguy's Avatar
20
Drives: 2016 328ix
2016 BMW 328ix  [0.00]
I have the same code that won’t clear either. Car drives great, no CEL. Luckily it’s not in permanent errors. Can’t find much info online. Did you get any answers on what might be going on?
      05-07-2021, 12:35 AM   #7
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
Hello,
I have the same problem since 03/31-2021 and for the moment everything is fine with my Xdrive, I just feel a few small bumps in cold start and very light foot on cold braking
A NOTER : ERROR 480AB5 DSC LMV - Uniquement avec Bimmerlink
      05-12-2021, 02:44 PM   #8
shiftdnb
Drives: 2017 F31 328dx
I got a CEL light today so I checked Bimmerlink. CEL looks NOx related but I too have this Code. I kind of freaked out because I have a staggered setup on Xdrive but I am in 1% on tire diameter. Anyone else with this error running staggered?
      05-16-2021, 09:19 PM   #9
Whatsupguy
Whatsupguy's Avatar
20
Drives: 2016 328ix
I’m staggered on factory OEM spec and have this error. Can’t clear the code but have not noticed any issues.
f30post
