The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > What are my options to increase fuel rail pressure?
      11-12-2020, 06:35 AM   #1
flipmode
flipmode's Avatar
63
Drives: 2009 BMW 335i
So over the past couple months I spent my time replacing oil pan gasket, while doing so I also changed out my rod bearings and installed RB Stage One turbos and Fuel-it stage 2 lpfp. I have also installed a new hpfp. I'm just in the process of finishing up my custom ethanol tune. We started at E30, then was able to bump it up to E35, and now tried out E40. My rail pressure has given out on e40. Just looking for feedback as to what options I have to run the e40 tune safely. I'm not looking to increase my ethanol content any further then e40. A few options I looked into are:
1) cheapest option-remove the hpfp filter and drill out fuel line(they claim a 300-400psi increase), what are your thoughts on removing the filter? This isn't my daily driven car, just a weekend driver.
2)helix overdrive-but Ive heard it can crack the brake booster housing bc of the extra weight and vibration
3) port injection
4)should I have went with a stage 3 lpfp? Would that have helped?
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
      11-12-2020, 07:00 AM   #2
Smgs1992
720
Drives: 2007 bmw 335i
Helix overdrive now includes a bracket so that it will not crack the brake booster.
Port injection is probably your other best choice
I dont think you’d need a stage3 lpfp if youre planning to just run E40. However i also dont think the lpfp is the issue if the hpfp isnt able to keep up
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
      11-12-2020, 07:59 AM   #3
NoGuru
NoGuru's Avatar
772
Drives: 335is
2021 Chevy Silverad ...  [0.00]
2002 Jeep Cherokee  [0.00]
2014 CTS  [0.00]
2011 335is  [0.00]
Wow does that tank fast.
If you want the cheapest option I would remove the filter and drill, but add a 10micron filter in-line someplace.
The best option (IMO) is port injection but it could cost you to get setup.
My setup is overkill but I have a Walbro 535 and 450 on a hobbs switch going to port injection and Bosch 550cc.
My HPFP usually sits around 2700psi on WOT.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
      11-12-2020, 10:52 AM   #4
Ten-Zing
27
Drives: 2010 335i x-drive MT
I recently went with the BMP Port Injection kit, at the time I ordered they were out of the plate style injector holder and were selling entire intake manifolds with injectors.
Went with that for marginally more money and it worked out really well. I lose the 'stealth' factor under the hood but that's not a big deal to me and really there's a lot of other cues under the hood to show it isn't stock now anyways.
Had to cut up the engine cover a bit as well to make room for the intake / injectors but it all works good.
      11-12-2020, 09:00 PM   #5
iqraceworks
iqraceworks's Avatar
2001
Drives: 2007 335i
Try a new HPFP........a healthy stock HPFP should be able to keep up with e40 and stage 1 turbos as long as the LPFP is supplying enough fuel...and it being a stage 2, it should.
I'm running an E50 tune with stock turbos and a stage 2 LPFP hitting 20psi....and I have no fueling issues at all.
I could be wrong....but I don't think the stage 1 turbos are a huge bump up from stock....but maybe I'm wrong.
      11-12-2020, 09:29 PM   #6
_N54
_N54's Avatar
300
Drives: 335d
A simple meth kit through the charge pipe will help. Run like a 70/30 mix or even 100% meth and your problem is solved.
2013 335is - sold
2011 335d
      11-13-2020, 05:52 AM   #7
flipmode
flipmode's Avatar
63
I have installed a new HPFP. As well RB's Stage Ones are a decent upgrade from stock. I am extremely pleased with them. Even my tuner was surprised how well they do for only stage 1's.
      11-22-2020, 11:01 AM   #8
flipmode
flipmode's Avatar
63
So just to follow up with what I have done, as it is good information for anyone looking to get an extra 4-500psi of rail pressure added on stock setup, I ended up drilling out my fuel line with an 11/64"drill, and removed the hpfp filter. I ran the same tune and I gained over 400psi. This is a cheap mod to get a bit extra fuel if your at your limits and need just a bit more.
      11-22-2020, 04:11 PM   #9
NoGuru
NoGuru's Avatar
772
Drives: 335is
2014 CTS  [0.00]
2011 335is  [0.00]
Originally Posted by flipmode View Post
So just to follow up with what I have done, as it is good information for anyone looking to get an extra 4-500psi of rail pressure added on stock setup, I ended up drilling out my fuel line with an 11/64"drill, and removed the hpfp filter. I ran the same tune and I gained over 400psi. This is a cheap mod to get a bit extra fuel if your at your limits and need just a bit more. Here is a log for you to compare with my first post log.
https://datazap.me/u/johnnyb12/log-1...0&data=3-15-16
Just make sure and add a 10 micron external filter asap.
      11-22-2020, 04:26 PM   #10
flipmode
flipmode's Avatar
63
https://datazap.me/u/johnnyb12/log-1...8;data=3-15-16
Yup. Planning that and also adding on an ethanol analyzer at the same time.
      11-23-2023, 08:42 PM   #11
titan.n54
Drives: BMW 335i
2007 BMW 335i  [0.00]
Was the modification sustainable over time? Any side effect in the HPFP?
      11-27-2023, 06:00 AM   #12
flipmode
flipmode's Avatar
63
Been running the same setup for over 2 years. All is good, no side effects.
      11-27-2023, 07:49 PM   #13
Pyrat_1M
PYRAT
Drives: BMW 1M
Which external filter did you use?
      11-28-2023, 08:35 AM   #14
flipmode
flipmode's Avatar
63
Spool Performance 10 Micron filter
