Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Fuel pump issues
      11-09-2020, 05:34 PM   #1
Renner335i
Renner335i's Avatar
Drives: 07 335i
Fuel pump issues
So I'm having a issue and im stumped. Car is a e90 07 335i. Mods are jb4 with custom tune, doc race 6466, mmp port injection with jb4 controller bmp stage 3 pumps with second on a hob switch at 15 pounds and supporting mods
The issue im having is this. 2 weeks ago the car was running great. Sat for 2 days and when i went to start up the car it was extremely rough and the radiator fan came on. So I pulled codes and got a high current code in the ekp and 2aae. Cleared codes and Fan didn't turn off till i cleared the epk high current. Now fan is off but reading my low pressure I am running around 79 to 82 psi when cold.
Hpfp is stuck at 2 then jumps to 11-12 which use to be steady 5 for me. So went for a drive. High side dropped to 5 now cruising. Low pressure is at 78 psi cruising. On map 1 (15psi) the low pressure goes above 80 and the high pressure drops to bellow 5 and the car just breaks up.
Anyone ever seen a issue like this before? Car just cant go full throttle now.
      11-09-2020, 11:24 PM   #2
lookalikehuuh
Drives: 2006 330i, 2007 335i
So I had the same codes from my EKP, turned out I have EKPM2 which is known to have issues with keeping up with the current needed by the Walbro 450 i installed in the car.
Eventually I figured out the real issue for me was that the EKPM was overheating so I bought some double sided thermal tape, small aluminum heatsinks, and a 40mm noctua fan from Amazon. Cut a hole on the top of the EKPM module and installed the heatsinks on top of the larger chips inside the EKPM.
Once the mods were done I also added thermal pad to the bottom of the EKPM board to the metal bottom, and added computer thermal paste to the actual bottom of the EKPM module to the metal stand off where it bolts on.
Its now been weeks since the installation and I have not seen a re-occurence of the code since the
Something similar to this, but I added addtional heatsinks to the 2 big black chips as well just for extra cooling.
View post on imgur.com
      11-09-2020, 11:26 PM   #3
_N54
_N54's Avatar
300
Drives: 335d
Picture isn't working. Is this common with the Walbro 450 or does this happen with the Walbro 535 also?
2013 335is - sold
2011 335d
      11-10-2020, 08:47 PM   #4
lookalikehuuh
Yes it can happen with any fuel pump that pull more current than the factory pump.
According to the Walbro flow charts the 535 uses like 3 amps more than the 450 for similar PSI, so I would assume the EKPM would be even more affected with the Walbro 535.
I added pictures from that post I originally tried to post. Anyway all the chips I circled in red are the ones that I added heatsinks to.
TiAgAu150.00
      11-10-2020, 09:07 PM   #5
lookalikehuuh
Oh I also forgot to mention, the guy from "Vehicular DIY" also has a video on how to upgrade you EKPM to an EKPM3 and then custom code it so that it won't give you the error... however its a bit expensive for a new EKPM3 and the coding is not for the faint of heart.
I found this other workaround and so far it has worked flawlessly.
If you have any more question let me know
      11-10-2020, 11:16 PM   #6
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
I was gonna say, I thought the newer EKPM3 modules could handle the Walbro 450.. no? The older EKP modules have issues, and with a 535 pump even with the newer EKPM3 modules have been known to overheat from what I've read
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
      11-10-2020, 11:35 PM   #7
lookalikehuuh
The EKPM3 also gives errors about excessive current from the Walbro pumps, companies like Fuel It try to say your EKPM is "weak" but the reality is that you are legitimately pulling much more current than it was ever designed for so of course its going to overheat.
For the record I did source an EKPM3 in the hopes that it would not have the same issue with current pull... it still did however have codes (different codes) than EKPM2 but still around the same thing. So instead of drilling a huge hole on the top of my brand new EKPM3 I did it to my old EKPM2 module and it was worked flawlessly.
      11-11-2020, 12:35 AM   #8
feuer
feuer's Avatar
Drives: wife crazy!
Renner335i issue is at start up and EKPM isn’t overheating then and won’t trigger fan and rough idle. Something else is up. Additionally, as you pointed out, coding is available to eliminate fault codes due to excess current. I’m highly doubtful that “your” fix that you are suggesting here would do anything to fix this issue.
      11-11-2020, 12:40 AM   #9
feuer
feuer's Avatar
Drives: wife crazy!
Do you get cylinder cut off fault when you go wot? Let me know if you are able to get oil level reading.
      11-11-2020, 04:57 AM   #10
Renner335i
Renner335i's Avatar
Drives: 07 335i
Yes i do get the injector cutoff code
      11-11-2020, 07:43 AM   #11
feuer
feuer's Avatar
Drives: wife crazy!
Last year, after an engine swap I was experiencing the same just without the fan coming on. Replaced everything fuel related. Process of elimination. Both sensors. Both pumps. All injectors. EKPM too. I have a lot of spare n54 parts. Problem didn’t go away. I had to drive like that so I did. If you wot it would back fire and go into limp mode with cylinder cut off code. Put 5-7k. Then I noticed I can’t read the oil level. That’s usually due to failing coolant pump. Replaced that and fueling issue went away too. Now I have ST, another car, that is doing the same, fan coming on too. Fuel gauge was fluctuating at 1/4 or bellow when you wot so I replaced the fuel regulator. Still getting cylinder cut off. Since I have parts I will start swapping. I know isn’t smart but I have been in the n54 game for a decade now and I don’t think there is a known cure for this particular problem. Judging from last year experience I thinking it might be debris in fuel or something electrical like a short that is affecting fuel supply. I will communicate with you as I go forward.
      11-11-2020, 08:43 AM   #12
Renner335i
Renner335i's Avatar
Drives: 07 335i
Im just trying to figure why my low pressure went from a normal 65 for me to 78 and sometimes higher at idle. Thats when i started really noticing issues
      11-11-2020, 09:09 AM   #13
feuer
feuer's Avatar
Drives: wife crazy!
That could be from lower ambient temperatures and lower ethanol content in winter fuel mix. I don’t think higher low fuel pressure than usual would cause this issue.
      11-11-2020, 09:13 AM   #14
NoGuru
NoGuru's Avatar
772
Drives: 335is
2021 Chevy Silverad ...  [0.00]
2002 Jeep Cherokee  [0.00]
2014 CTS  [0.00]
2011 335is  [0.00]
I would look at the Fuel pressure regulator or like feuer said, could be debris in the system someplace.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
      11-11-2020, 09:41 AM   #15
Renner335i
Renner335i's Avatar
Drives: 07 335i
Understood. Car has 95000 on it so a new regulator cant hurt. I'll do the sensors as well.
      11-11-2020, 06:36 PM   #16
Renner335i
Renner335i's Avatar
Drives: 07 335i
So car sat for 2 days. Maybe this is some helping info. Got in car and started logging low pressure psi, current and voltage. Started car and battery was low as it did struggle to start a little. I have the cold start delete on but car started to stumble, fan kicked on and no check engine light Low pressure was around 92 at first, voltage showed 9.8 and bouncing around and current was 19.1a and bouncing. Then i got the high current code and 2aae. Weird thing is rail pressure was reading 78.1. Cleared codes. I actually had to a few times to get the car to,keep the codes away then I am at 86 psi and bouncing, 13.1a current. High pressure is between 650 and 750 now but now codes. Just so erratic but the high current would make sense pulling 19.1a when i have the issue
      11-14-2020, 07:42 AM   #17
Renner335i
Renner335i's Avatar
Drives: 07 335i
So i replaced the regulator. Now pressure is back to 64-65 at idle. So i did a little brake boost to see what would happen once boost kicked in. Low pressure rose to 68 and high pressure dropped hard to 300 psi and then 29dc injector cutoff. Sounds like high pressure pump is going out. What do you guys think?
      11-17-2020, 08:36 PM   #18
Renner335i
Renner335i's Avatar
Drives: 07 335i
Replaced the hpfp with one from a buddies car as its the last thing to try. Turned on and no stalling, no codes and full pressure rises on the high side when i rev. I noticed when I spun the used pump it was kinda spring loaded where mine spun freely. Is that a sign of a failed pump?
      11-24-2020, 08:45 PM   #19
feuer
feuer's Avatar
Drives: wife crazy!
Do you get 29dc injector cutoff with the other HPFP ?
      11-26-2020, 04:40 AM   #20
Renner335i
Renner335i's Avatar
Drives: 07 335i
Yes. It got to the point that the car would stall and 29dc. I replaced the pump and car is rock solid
feuer4275.50
      11-26-2020, 08:27 PM   #21
feuer
feuer's Avatar
Drives: wife crazy!
I’m glad. That’s what I was doing today. I removed new HPFP and installed old from another car for testing.
