11-08-2020, 12:45 PM | #1 |
Rep 28
Brake replacements help
Hello,
I was wondering if anyone could help confirm I have chosen the right parts for my brake pad replacements. I have a 2014 Msport trim, with the basic brakes you get on all stocks. Article numbers below for online car parts .co.uk B111337 - front Brake pads 6637 - Rear Brake Pads 407W0075 - wear indicator 407W0070 - wear indicator Many thanks |
11-09-2020, 04:30 AM | #2 |
417
Rep 919
realoem.com will confirm all your part number needs.
The part numbers you've listed don't 'align' with bmw part numbers, so guess these are from some online store--can't help you confirm your parts. Also, you may need rotors--but they often will run two sets of pads. With a $10 micrometer, you can see if they're above minimum thickness (which is stamped on the rotor somewhere usually.) Anyway, enter your vin at realoem and bookmark the page--if you have a bmw, you'll need it again.
