11-06-2020, 09:45 AM | #1 |
878
Rep 1,687
Drives: 2014 428i and 2018 X5
Hey guys, so I was going to help a friend of a friend change the transmission fluid and put on a new pan on his F30 he recently bought. It has over 75k mikes and no warranty.
I've changed the pan and fluid on my car so it was no big deal and figured I'd make a quick 50 bucks. However once we got the car up on jackstands, I noticed that the transmission fill plug was completely stripped. I tried a couple different variations of T50 sockets and even broke my torque wrench trying to get it out. It's seriously torqued down by whoever did this before. Does anyone have any advice on how to get it out, given the very little clearance there is because of the exhaust pipe? Please see attached pic and thank you!!!!
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
11-06-2020, 10:18 AM | #3 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Funny, I too stripped mine when putting mine back on after doing my trans service. I got mine to tighten down to about 40ft/lbs because it stripped. No leaks. Was going to deal with it when I go back in there and service the trans again.
Best of luck. As stated, I would try to chisel it in and fit a flat head into it. I was thinking maybe there's enough room to grip it with channel locks or locking pliers. |
ooshnoo877.50 |
11-06-2020, 10:38 AM | #4 |
1728
Rep 536
That looks a lot like what happens when you use a Torx instead of the plug removal socket.
You can try welding a nut to the plug and rotating it off that way. Depending on the torque it rounded out at you might even be able to use JB weld. I drew up a crude diagram of how that might work. |
ooshnoo877.50 |
11-06-2020, 11:59 AM | #5 |
878
Rep 1,687
Thanks guys. My neighbor is a welder. Will ask what he thinks later on today.
11-06-2020, 12:22 PM | #7 |
878
Rep 1,687
No sir. Was about to, but then I noticed the stripped plug.
12-12-2020, 07:45 PM | #8 | |
878
Rep 1,687
12-14-2020, 07:13 AM | #9 |
34
Rep 356
all of these are too complex solutions. this has happened to me twice in two different e90s and i was easily able to remove the fill bolt with the following tool: https://www.homedepot.com/p/Husky-Pi...0111/309997715
it can be done at home with no special tools like welders, etc. For future reference if anyone else ever has this issue...
2016 340i | M-Sport | Mineral Grey | Coral Red | Bone Stock
sspade2466.00 |
12-14-2020, 07:16 AM | #10 | |
878
Rep 1,687
12-14-2020, 02:21 PM | #12 |
21
Rep 49
Had a super tight fill plug one time. Wasn't stripped, but was so tight I was afraid it would strip. Used a propane torch to gently heat the pan are around the bolt; not the bolt itself. This did the trick
12-14-2020, 06:47 PM | #13 |
436
Rep 844
If you broke a torque wrench on it that's really tight! I wonder if they stripped it so much they couldn't tighten it to spec and squeezed epoxy on it to hold and seal it and maybe that's why you can't remove it?
Subscribed though, interested on how this turns out
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
12-16-2020, 02:08 PM | #14 | |
878
Rep 1,687
BWbimmer276.50 |
