Another 335, another o2 sensor problem
11-06-2020, 07:05 AM | #1 |
Rep 107
Just picked up an 09 335xi 2 door 6mt. Did the normal dci, charge pipe, new valve cover and gasket, one step colder plugs, down pipes, jb4, mhd bef. And have had nothing but issues with 02 sensor codes like my last car had. Going to order a bank two front sensor today. There's the codes that keep popping up think it's just the sensor or another issue?
Black 09 335xi coupe 6MT
Down pipes, Charge Pipe, DCI, JB4, 2 Step, BEF, 3.5 Bar, |
11-06-2020, 07:14 AM | #2 |
2341
Rep 3,539
This all came after you did all that other work?
Did you check that the O2 sensors are plugged back in correctly after valve cover work? |
11-06-2020, 10:36 AM | #3 |
Rep 107
Started after the downpipes I believe. I was careful with the sensors marked them so I knew where to put them back in at. I'm picking up a new Bosch bank two sensor from pep boys today. I'll see if it makes a difference. My last car had never ending issues too. Mostly because of a cracked valve cover. This once's brand new so it shouldn't be that. But I might have to smoke test it to make sure
