11-05-2020, 08:49 PM | #1 |
Rep 29
Just installed CTS turbo CP (issue need help)
So I just installed a CP as I’m getting ready for BM3 and as I was doing test to make sure it’s in and on properly I noticed hissing and lots of turbo sounds. So I figured try sports mode plus to get higher rpms and I feel a bit of a shake not sure where but most likely CP then I figured might aswell give it a pull to see if it’s safely in there and got a warning of drivetrain malfunction any ideas on what I may have messed up on the CP is still intact. I did tighten the screws for if I was to use meth injection
11-05-2020, 09:01 PM | #3 |
Rep 29
CTS did give me new o rings but I removed them to put on the old ones but I may have put the bottom one ( connects to IC) on incorrectly would that cause the shaking and hissing? I was having trouble with getting it to sit in place since the O ring seemed just slightly larger
11-06-2020, 01:37 AM | #5 |
3082
Rep 4,333
more than likely it is your o-ring. its of utmost importance that it is oriented correctly, seated properly and it's not twisted or distorted.
https://f30.bimmerpost.com/forums/sh...+o-ring&page=3 https://f30.bimmerpost.com/forums/sh...2&postcount=38 |
DrBall125.50 |
11-06-2020, 02:33 AM | #6 | |
Rep 29
alohasurftoad3081.50 |
11-06-2020, 07:52 AM | #7 |
126
Rep 136
i did the same thing when installing the IC connection... flipped the ring around and problem solved! easy fix
2013 335i Xdrive Msport
11-06-2020, 08:53 AM | #8 |
Rep 29
11-06-2020, 03:37 PM | #9 |
Rep 29
So I flipped the O ring and couldn’t get the CP to connect properly on the IC so I had to pull it out of the silicone sleeve a bit and now the pipes don’t touch not sure I had it in before to where there was a very little gap. Initial test drive and noticed a flapping sound when Stopping. Tighten clamps again to make sure it’s on super tight now no sound but it was a little test drive. Any words of advice on if I notice the sound again?
