11-05-2020, 11:40 AM | #1 |
Rep 23
difference in wheel well covers & correct size fender screws
super basic. but i need a new wheel well cover. i see some have a slotted square and others are solidly covered. ref the dif in these two. my question is what is the purpose/importance of that square hole being slotted? on the drivers side theres nothing behind it, and passenger side is an oil cooler. links to each im looking at below.
slotted solidly covered also, i thought i had oem fender screws but they are not working the clips on a replacement splashguard i got, so im guessing a shop used whatever they had at some point. what is correct size screw and clip, m6 1.0 or something else? |
11-05-2020, 12:56 PM | #2 |
8245
Rep 16,083
Slots are for ventilation. Look up the fasteners at https://www.realoem.com/bmw/
11-05-2020, 01:49 PM | #3 |
1646
Rep 4,877
I don't think you need slotted. Mine are slotted to allow air to pass from the auxiliary radiators in the grill out through the wheel well. I don't believe the 328 would have those, but others can correct me if I'm wrong.
11-05-2020, 02:04 PM | #4 |
8245
Rep 16,083
I'd say he needs to get the same configuration as the one he's replacing.
Silverlining_m21734.50 |
11-06-2020, 02:07 AM | #5 |
277
Rep 833
Drives: BMW F36, E36, E93
These are the screws to go with the metal clips behind: TS5X17 SW8 D=22
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
11-07-2020, 05:29 PM | #6 | |
Rep 23
billfitz thanks for that amazon link, ive seen that but review and one with pics shows may be slightly dif, also says e90 not f30 which makes me hesitate. altho the ones that screw into the "chassis" must be right where as most the others use same size clips as screws around the fender coverings where they screw into each other. |
