11-04-2020, 10:01 AM | #1 |
27
Rep 85
Winter Tire/Wheels for ZTK M340
Hey all, I'm trying to figure out what to do for winter tires for an M340 on order.
It's xDrive and the dealer is saying that it's coming with Michelin Pilot Sport 4S tires in the winter here. It should have 225/40R19 on a square setup (?). I'd like 18's for the winter, but the only 18 that anyone says will fit are the 796Ms. I could use the stock wheels and just buy some winter tires, but I'd rather have a wheel set. These MSW Type 73 wheels are nice but the tire sizes are non-standard so you can't really get the best winter tires and they're 19"s so thinner sidewalls aren't really ideal with nasty winter roads. What are you all doing or what do you recommend? |
11-04-2020, 10:27 AM | #2 |
715
Rep 1,205
I too have the ZTK and recently bought a winter set. I was considering the OEM 796M 18 Black wheel & tire setup that does in fact fit the larger brakes. I ended up going with a set from Tire Rack.
They came mounted and balanced with the TPMS on Yokohama Winter V905 225-45/255-40 This set has near identical specs to the OEM winter offering. I usually go square in winter with 225 but decided to maintain that performance vibe. I will be switching next week.
20 M340xi White Mocha
17 340i/M235i/E92 M3/135i All 6spd Chicago-Lake County-Milwaukee-Shorewood |
obscurehero27.00 |
11-04-2020, 10:29 AM | #3 | |
27
Rep 85
11-04-2020, 10:43 AM | #4 |
715
Rep 1,205
The math is the same so they should. I can verify next week. I'm in Milwaukee myself. I see youre in WI, you should be okay on summers for a couple of weeks to give you time to decide/research. If youre in doubt now and need to pull the trigger on a set just go OEM 796M set. If you can wait you maybe can save 4-500 even with a 19inch set
11-04-2020, 10:49 AM | #5 | |
27
Rep 85
11-04-2020, 11:00 AM | #6 |
715
Rep 1,205
I'll let you know and you can take advantage of any Black Friday Steals.
Shame they switched bolt pattern as I had a nice set for my F30 340i that fit the ZTK brakes.
11-06-2020, 10:10 AM | #7 |
715
Rep 1,205
They passed the eye test. Will follow up next week.
11-06-2020, 10:46 AM | #8 |
27
Rep 85
Looks good! Let me know once you've got them on! I might order these if it works out. They look clean.
2021 M340i xDrive - Current
2016 340i xDrive, M Sport - Retired |
04-24-2021, 08:55 AM | #9 |
28
Rep 67
04-24-2021, 09:20 AM | #10 | |
715
Rep 1,205
Got these instead https://www.bimmerpost.com/forums/sh...php?p=26922499
04-24-2021, 09:27 AM | #11 | |
28
Rep 67
04-26-2021, 08:04 AM | #12 | |
299
Rep 564
Drives: BMW G20 330i X-Drive M-Sport
04-26-2021, 11:29 PM | #13 |
72
Rep 122
It looks nice! I have no experience with Yokohama winter tires, most of my friends usually have Bridgestone Blizzak or Michelin Xi3 on their vehicle. You can check 4wheelonline for a wide variety of snow tires and wheels that are suitable for your ride.
