Help! Electrical malfunction car dead....
11-03-2020, 06:50 PM | #1 |
7
Rep 132
Different symptoms than post below. Car had been driving fine just a
Few hours ago...well pulled out of Walmart just now and every warning light possible turned on along with the car shifting to neutral and finally killing the engine. When I turn the ignition back on I get a ton of dif codes along with the wipers going no stop. Additionally my JB4 connect will not establish a handshake. Will post codes momentarily. 2011 FBO 335is JB4 w/mhd bef
Present garage 2011 335is ,2006 Range Rover sport SC, 2005 GSXR-750, 2003 Jeep Wrangler Retired/sold 2009 e92 m3-totaled, 2008 e92 , 335i fbo ,2011 ZCP e92 m3, 2007 E60 M5, 2008 ZO6 C6 Vette, 2006 evolution MR, 1999 VR-4
11-03-2020, 08:45 PM | #2 |
7
Rep 132
Resting voltage on the battery is 11.7 which is peculiar given the battery is 90 days old. Its also odd that the JB4 refuses to connect. any help or suggestions where to start would be greatly appreciated.
BimmerGeeks ProTool Date: 11.03.20 05:33 PM Vin: NOTFOUNDXXXXXXXXX Chassis: Model: Engine: Body Style: ****************** Errors ****************** -------------------------------------------- FAMILY [VARIANTE] | CODE: DESCRIPTION -------------------------------------------- JBBF [JBBF70] | C918: No message (wiper operation, 0x2A6), receiver JBE, transmitter FRM/SZL/LWS/IHKA JBBF [JBBF70] | C90B: PT-CAN communication fault DWA [DWA_63] | No errors found PGS [PGS_65_2] | No errors found FAS [FAS_PLX] | No errors found RDC [RDCKWP] | No errors found CAS [CAS] | A0B1: Input, selector-lever position, implausible CAS [CAS] | A0B5: Fault, road speed signal CAS [CAS] | A118: Roadspeed signal implausible ZBE [ZBE_60_2] | No errors found BFS [BFS_PLX] | No errors found FRM [FRM_70] | A8C5: Daytime running light, left, faulty FRM [FRM_70] | A8C6: Daytime running light, right, faulty FRM [FRM_70] | A8A9: High beam/turn-off light, right, faulty FRM [FRM_70] | A8A8: High beam/turn-off light, left, faulty FRM [FRM_70] | E59C: No message (steering angle), receiver FRM, transmitter SZL/LWS/DSC FRM [FRM_70] | E594: No message (steering angle), receiver FRM, transmitter SZL/LWS/DSC FRM [FRM_70] | A8AB: Low beam, right, faulty FRM [FRM_70] | 9CC0: Communication with step motor controller on the right disrupted FRM [FRM_70] | 9CBF: Communication with step motor controller on the left disrupted CID [CID_90] | No errors found KOMBI [KOMB87] | A3AA: No description found KOMBI [KOMB87] | A3AC: Message (distance travelled, 0x1A6) faulty, receiver KOMBI, transmitter DSC KOMBI [KOMB87] | A550: Message (speed, 0x1A0) faulty, receiver KOMBI, transmitter DSC KOMBI [KOMB87] | A565: No message (display, engine data, 0x175), receiver KOMBI, transmitter DME-DDE KOMBI [KOMB87] | A3AD: Message (engine data, 0x1D0) faulty, receiver KOMBI, transmitter DME-DDE KOMBI [KOMB87] | A3AB: Message (LDM, 0x190) faulty, receiver KOMBI, transmitter LDM KOMBI [KOMB87] | A3B9: Sporadic fault (failure, DSC message, 0x19E) No repair measures available, receiver KOMBI, transmitter DSC KLIMA [IHKA87_2] | E72F: Message (status of DSC K-CAN, 0x19E) faulty, receiver IHKA, transmitter DSC KLIMA [IHKA87_2] | E717: Message fault (engine data, 0x1D0), IHKA receiver, DME-DDE transmitter KLIMA [IHKA87_2] | E71A: Message fault (torque 3, 0xAA), IHKA receiver, DME-DDE transmitter KLIMA [IHKA87_2] | E71C: Message fault (speed, 0x1A0), IHKA receiver, DSC transmitter KLIMA [IHKA87_2] | E71B: Message fault (heating current engine, 0x1B6), IHKA receiver, DME-DDE transmitter KLIMA [IHKA87_2] | E720: Message error (power management, consumer control, 0x3B3), IHKA receiver, DME-DDE transmitter CVM/CTM [CTM_93_6] | No errors found MRS [ACSM2] | 93FB: No message (vehicle speed) from DSC, ACSM receiver / MRS5, DSC transmitter VIRTSG92 [] | No errors found VIRTSG92 [] | No errors found TEL/MULF [TELE60_3] | No errors found ISPB [ULF2_HI] | No errors found VIRTSG92 [] | No errors found VIRTSG92 [] | No errors found FZD [FZD_87] | No errors found
11-03-2020, 09:46 PM | #3 |
2124
Rep 2,758
Car dying, wipers going crazy and tons of warning lights are a classic sign of the car not getting enough voltage from the battery. Either the battery or alternator is the blame since I see no codes relating to the IBS.
If you have a pretty new battery then it's most likely the alternator. Mine went out a few months back and many of the same things happened to me that yours did and I needed a new voltage regulator for the alternator. |
11-03-2020, 11:58 PM | #4 |
7
Rep 132
Thanks for the reply.
Wouldn’t I see some kind of progressive failure if it was the alternator like the car struggling to start or some other weird voltage failures? I’m a little worried the CAS or FRM shorted out or something as equally catastrophic. I removed the battery and put it on the charger and we’ll see where it’s at in the morning. I also noticed when I went to restart the car the transmission wouldn’t go into gear and it didn’t want to turn over correctly. Not to mention isn’t odd I couldn’t even connect via BT to the jb4? |
11-04-2020, 12:02 AM | #5 |
2124
Rep 2,758
Nope, not necessarily. My car started fine, drove to a few places, sat in a drive through, then started driving home. All the sudden on the way home the battery finally drained enough to make the wipers go crazy and then a few seconds later my car almost overheated due to the water pump being shut off due to not enough power. Shut the car off and when I came back to start it to take it home after cooling off and the battery was dead.
I'd charge the battery fully and make sure it has a full charge, then put it in and see what happens. If you can start the car I'd check the alt voltage right off the back of it, mine was actually overcharging(16+ volts). |
11-04-2020, 02:12 PM | #8 |
7
Rep 132
edit sorry for the lack of punctuation.
Fully charged battery. cleared codes, CAME right back. Rinse and repeat, I can get the car to actually start it will turnover though or I’d pull a reading from the alternator. Any other suggestions?
11-04-2020, 04:40 PM | #9 |
2124
Rep 2,758
11-04-2020, 06:55 PM | #10 |
110
Rep 257
I'm having these same exact issues tonight I'm going to try replacing my alternator and see if it fixes the issue. My car almost died on me dash is lit up wiper blades going crazy coolant light popped up then randomly got power back and the transmission didn't want to shift at all speedometer doesn't work etc..
11-04-2020, 06:57 PM | #11 | |
110
Rep 257
11-04-2020, 06:59 PM | #12 |
2124
Rep 2,758
If the battery is fully charged(and actually reading 12.4+ with a multimeter, not just the charger saying it's full) and the car won't try to turn over then I doubt it's an alt or battery issue.
Wheres gbalthrop |
11-04-2020, 07:02 PM | #13 |
2124
Rep 2,758
The alternator is not very easy to change out on these cars, I would try to pin point the problem before trying to just swap the alt if at all possible
11-04-2020, 07:06 PM | #14 |
69
Rep 113
Wasn't there a recall years ago on the power wires from the battery or something. There was some sort of corrosion or connection issue. I cent remember what it was because it was before my time.
11-05-2020, 07:46 AM | #15 | |
110
Rep 257
11-05-2020, 08:45 AM | #16 |
7
Rep 132
I highly doubt its the alternator as well. Thanks for the reply BTW. You are correct, swapped a fully charged battery and the issue is till present. Im absolutely stumped...like I mentioned something peculiar I noticed is with the ignition on my Iphone will not connect to the JB4. is it possible that power is being interrupted somewhere before it makes it to some modules?
11-10-2020, 02:40 PM | #17 |
7
Rep 132
Bump. I'm still experiencing issues, the only way I can get the car to actually start is by disconnecting the IBS however the same codes still register. Is it possible the DME itself is not getting power which would explain why the JB4 inst powering on as well?
11-11-2020, 04:38 PM | #20 |
7
Rep 132
Where is that located in the e93? There was a half tire sized cover over the wires running to the most-bus and the top side of the cover did
Have some moisture on it. The bus itself looked dry. |
11-14-2020, 09:03 PM | #21 |
7
Rep 132
So Im still struggling to chase this down. Battery & Alternator are 100 percent good. Today I pulled the fusebox and JBE. The B+ cable looks brand new zero signs of corrosion same with the JBE itself. Additionally I checked all the grounds under the hood including the grounding strap as well as the grounds off the battery to no avail. The OBD port is also non-functional as well, the only way I can pull codes is protool because it reads all the modules. Is there anything that the windows based software can do that I can't replicate in protool?
11-20-2020, 04:28 PM | #22 |
63
Rep 137
I had very similar issues a year ago. No symptoms of the car dying, went to lunch, came back and the car was crazy. All lights and warnings, wipers were nuts, car wouldn't run so needed to be towed home. Culprit was the voltage regulator on the alternator. I believe the stators in the regulator are a wear item and they can fail without notice.
A new VR was $100 (Aussie dollars) where a new 180amp alternator was going to be $1500... from memory you can swap the regulator with the alternator still in the car. I believe you can test this witha a multimeter, but for me it was obvious the VR was the problem when I removed the old one, as one of the stators was very worn and not making contact in the alternator. Hope this helps your problem. I was so very happy it was k my the VR for me... |
