f10 front dif swap into e90/92 possible?
11-03-2020, 08:17 AM | #1 |
Rep 30
Has anyone tried to swap in a f10 front dif into their car? My front dif seized 3.08 as it is manual however finding a front dif is proving to be quite challenging. However, there are plenty of f10 newer generation front difs available however the part numbers do not match not sure if it would bolt up however if it did i don't see why it would not work. My part number is 3150757578 if anyone has any other suggestions for me please let me know thanks.
2011 335xi -JB4/MHD/Purestage 2 Turbo/BMS Intake/VRSF Charge Pipe/BMS Meth/Catless/Fuel It stage 2/VFRS 7inch FMIC/N20 Flex Fuel
Dyno'd at 475Awhp/473tq |
11-05-2020, 05:44 PM | #2 |
8
Rep 80
Extremely unlikely. Beware, there is also a difference, apparently, between builds up to 04/08 and anything after. Difference however, is not clear.
I'm on the same search my friend. Good luck, the choices blow. These front diffs are evidently problem prone. |
