11-02-2020, 09:51 AM | #2 |
336
Rep 365
ESYS is for flashing or coding. I do not believe it is used for reading diagnostics data. If you want to monitor DPF values, such as temperature sensors, calculated soot and ash volumes, pressure differentials, computer-calculated anticipated replacement counters and such, you either need to download BMW's ISTA+ software or invest in a Veepeak adapter and phone app, such as BimmerLink. With the app, you're able to monitor DPF as well as other systems with ease and on the go. ISTA+ is of course the best diagnostics software you can get, and all you need is a $20 ENET cable. Best of luck to you!
11-02-2020, 10:06 AM | #3 | |
Rep 55
