Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Help for towing
      10-30-2020, 03:07 PM   #1
m4dman
40
Drives: BMW M4CS
Help for towing
Hey guys I have a friend that needs Help putting his car in neutral manually ? Any instructions on a neutral release on a 2020 m340? Please thank you for the help !
      10-31-2020, 01:50 PM   #2
M340_pilot
88
Drives: 2020 M340i
Here you go
Sold: 2020 M340i, BM3, VRSF catted dp, MPE, Dinan springs
m4dman40.00
      10-31-2020, 03:06 PM   #3
M340_pilot
88
Drives: 2020 M340i
Recommend downloading the BMW Driver's Guide app.
Appreciate 2
m4dman40.00
      10-31-2020, 11:09 PM   #4
m4dman
40
Drives: BMW M4CS
Thank you guys! We fumbled around and figured it out from the manual !
      04-21-2022, 08:39 PM   #5
cpeeinc
cpeeinc's Avatar
Drives: bmw 330i
I’m currently in the same spot with my car. My body domain module is damaged and I need to move the asap
      01-22-2023, 12:28 AM   #6
g21
g21's Avatar
3584
Drives: M340T M550i EV6GT
hmm just trying to figure this - so if your car/engine won't/can't start, then there is no way to put transmission into neutral?
      01-22-2023, 10:17 AM   #7
G22b58
93
Drives: G22
Haven't (needed to) try but the instruction says as long as the starter motor can rotate the engine, keep pressing the start button while selecting N on the gear lever. Release both and the gearbox shall stay in neutral.
Have no idea what to do if power is lost, but then my parking brake is probably also engaged.
      01-26-2023, 01:39 AM   #8
g21
g21's Avatar
3584
do you select N by moving the gear stick without pressing the side button?
Search this Thread:
Advanced Search
g20
