Rb replacements to Ones, worth it?
10-30-2020, 09:28 AM | #1 |
858
Rep 1,363
Drives: 09 E90 335i M-Sport 6MT RWD
Short version: My daily is the 335 sedan. Full FBO + inlets/outlets and a JB4+BEF. I also have meth waiting to be installed when I get around to screwing with it.
I installed some RB oem replacements when fixing the wastegates 1.5 years ago. My father also has a E90 335 and we just grabbed some RB ones as a good deal to replace them. He is also FBO and the turbos came with inlets. He really has no need for the bigger turbos as the car is quick as is for him. I can do the labour/work no problem; Just is there any real benefit of going up to the ones or are the gains that minimal? Its my daily and I do have faster cars (the miata) and I don't really want to be breaking things/dealing with fueling issues or making the car less reliable. |
10-30-2020, 11:49 AM | #2 | |
973
Rep 3,219
Your miata is faster than FBO N54? lol |
10-30-2020, 11:54 AM | #3 |
858
Rep 1,363
Correct, Substantially faster lol
Miata is ~350whp on a conservative tune and weighs just over 2100lbs. FBO 335 on stock turbos might hit 400/420whp and my rwd manual version weighs 3600lbs. Besides the feeling/ burying the speedo; the math supports it. Also both cars run 91 Octane |
10-30-2020, 01:17 PM | #4 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
https://www.n54tech.com/forums/showthread.php?t=33200 You will need a custom tune either way. $350.00 minimum. You will also need a stage 2 LPFP. You should easily be able to make 475-500 hp on RB 1's with inlets & outlets. Just make sure you are on Eldor Coils & NKG stage 2 plugs gapped at .018 I'd also make sure you have index 12 injectors |
10-30-2020, 01:20 PM | #5 | |
973
Rep 3,219
0-60 will probably be faster against a rear wheel drive 335i. |
10-30-2020, 01:22 PM | #6 |
858
Rep 1,363
I own the miata and we have 2 FBO N54 E90s(both have LSD's btw). The miata is faster in every regard lol; Its not even a contest. Its also on a conservative tune for track (I'm sure I could add a bit more boost and try to push the limits of the 1.8L but why)
10-30-2020, 01:26 PM | #7 | |
858
Rep 1,363
Is the LPFP necessary? I might just dial back the boost a bit to start and see where I'm at before going that route. Fueling issues is not an area I want to dig into |
10-30-2020, 01:34 PM | #8 | |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
And OP yes you'll want to look into a stage 2 lpfp soon enough after install at least, you will start to starve the hpfp keeping up from what I have gathered.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-30-2020, 01:54 PM | #9 |
449
Rep 823
I'm still curious about this Miata! What all does one need to replace on a vehicle that has almost 4 times the power it was designed for? Sounds like an absolute rocket to me with that power to weight ratio! You have any videos of it?
2008 335xi 6MT - 16T China Turbskies - eBay FMIC, DP & CP - VRSF Inlets - SSR DCI's - Walbro 450 LPFP - RFP e85 Tune
10-30-2020, 02:02 PM | #10 | |
858
Rep 1,363
Then again there's Honda K20/K24 or LS swaps if you're shooting for the moon. It by no means a good daily driver but if you want that real driving experience; I've yet to find anything better for even close the money |
stewbets448.50 |
10-30-2020, 05:00 PM | #11 | |
973
Rep 3,219
Otherwise 350whp will not win against 420whp top end. A tuned Xdrive 335i will leave it for dust. 1.8 lamo |
10-30-2020, 06:07 PM | #12 | |
858
Rep 1,363
If you would like to discuss both my personal vehicles, my experience as a performance engine builder or physics(power to weight) my pm is always open. |
10-30-2020, 06:42 PM | #13 | |
449
Rep 823
Also, you drive a turbocharged 3.0L engine (SO MASSIVE) and are displacement-shaming someone else? Why not leave that to the V8 NA crowd? |
10-30-2020, 07:10 PM | #14 |
195
Rep 305
There is a reason why there are RB oem replacements, Rb Ones, RB Twos, RB Twos plus, Standard GF's and High Flow GF's..
Email Rob and he will most definitely give you an honest answer to your questions.. best N54 turbo builder bar none with the best customer service.
08 E90 335i - MONTEGO BLUE
JB4/MHD E85 BEF - RB TWOS PLUS ECS CARBON DCI - BMS CHARGEPIPE NRW CARBON COWL FILTERS - TIAL BOV VRSF 7.5 RACE FMIC - VRSF INLETS - VRSF OUTLETS - VRSF DOWNPIPES BMS PEDAL TUNER - VTT DUAL CATCH CANS 3.5 BAR TMAP - NGK 97506 PLUGS H@R SPRINGS - NRW V1 PADDLES PFS STAGE 3 LPFP - PFS V2 PORT INJECTION MOSSELMAN OIL THERMOSTAT MISHIMOTO 25 ROW OIL COOLER SPOOL PERFORMANCE ETHANOL ANALYZER MISHIMOTO 15 ROW TRANSMISSION COOLER ZIMMERMAN DRILLED ROTORS - EBC REDSTUFF PADS |
10-31-2020, 06:25 AM | #16 | |
973
Rep 3,219
There have been several tests showing, that cars and bikes even against high performance cars which weigh a lot more, initially the lower powered (higher power to weight ratio) vehicle out accelerates the high powered (lower power to weight ratio) car, such as 0-60, or 0-100 mph sprints, after that the heavier high performance car gains on it and beats it. When did I ever say 3 litre was remotely massive? Facepalm, that's average size, if you really asking, the saying about there's no replacement for displacement does have a point. I was referring to the massive turbo lag on a 1.8 that's been tuned to 350hp, and not the engine size itself, but thanks for jumping to conclusions and assuming otherwise. XDrive 335i FBO's have done 0-60 in around 3.6 secs, how fast can a 350hp Miata do it, considering it doesn't have all wheel drive ? Last edited by Saif2018; 10-31-2020 at 06:31 AM.. |
10-31-2020, 07:51 AM | #17 |
1209
Rep 2,476
Just stop it already. Start another thread if you want to discuss power/weight. Here's your homework assignment for that thread-assuming straight line only, and all else equal- Car #1 @420WHP and 3600lbs Car #2 @350WHP and 2100lbs Which is faster to 60, 100, 130? |
10-31-2020, 09:21 AM | #18 | |
973
Rep 3,219
Nevermind. |
10-31-2020, 10:13 AM | #19 | ||
Chelsea Football Club
345
Rep 780
I run an e50 tune stock turbos LPFP and I'd say your Miata with almost half the weight cut would smoke my E92 in every regard. You know what you run a 1/4 mile in? |
10-31-2020, 10:29 AM | #20 |
2685
Rep 4,202
You all know what this means right? Weight loss time for the e92!!
Also, let's respect the question. Is it worth it to switch to RB ones from stocks when you already have a faster stable of cars? I mean, no, probably not lol... unless you love doing the labor
10-31-2020, 11:37 AM | #21 |
1209
Rep 2,476
10-31-2020, 12:39 PM | #22 | ||
1903
Rep 6,968
However, if you have hybrid turbos & a stage 2 LPFP, why wouldn't you run a some e30 or even e50 once in a while? That would 🤩 |
