Coolant leak help
10-28-2020, 04:42 PM | #1 |
Rep 46
Coolant leak help
Was driving my e91 after it being parked up for awhile, and the low coolant popped up yellow which turned to red. I pulled over and coolant was leaking from this part pictured here. Not the actual hose, but the piece that it’s attached to. Anyone know name or part number
10-28-2020, 05:11 PM | #2 |
320
Rep 1,023
Is this it? https://www.fcpeuro.com/products/bmw...er-17127531579
Recommend going to www.realoem.com, entering the details of your car, and verifying the location/looks/part-number of the needed part. The hose and that plastic fitting are one piece.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
10-28-2020, 05:19 PM | #3 |
626
Rep 2,099
You sure it was from there and not trickling along the side (remember force as you drive forward) and down from a fissure on the radiator outlet? Just saying this because I just went through this. Otherwise, I can tell you its going to be hard to find the o-ring for that one (Which would be a better course of action). BMW likes to just sell the whole hose on most of their coolant parts. Only o-ring they readily sell is the tranny cooler hose one that plugs into the radiator.
If you get desperate and don't want to buy the whole assembly (as I think that's part of the spider), then there are some ebay auctions out there with the o-rings for the whole system. |
