F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Tail light malfunction
GetBMWParts
      10-27-2020, 09:07 PM   #1
Moab Bimmer
BMW Owner
Drives: 2012 BMW 328I
Exclamation Tail light malfunction
I recently purchased a 2012 BMW 328i ( Luxury Trim, Upgraded Electronics Trim ) and am having a issue with the rear taillights. Ill start off this thread by listing what tail lights DO work:
- Rear Driver Running light
- Rear Passenger Trunk Running light
- Rear Passenger Brake/Signal light
What DOESNT work:
- Rear Driver Break/Signal Light
- Rear Passenger Running Light
- License Plate Lights
Keep in mind this vehicle doesn't have the upgraded lighting package, the bulbs were just changed, and the taillight connectors look in good condition (Not Burnt, Flailed, ETC.) The Infotainment system isn't showing any faults in the lighting system, no check engine lights, lights are not triple blinking like they would if there was a problem with the tail lights.
      10-28-2020, 02:18 PM   #2
davidr3
448
Drives: 335i
Had a similar issue with my vehicle, dealer had to replace bulbs, the issue persisted and they ended up replacing something along the lines of the connectors I believe. Try double checking your connectors and if not, i'd look into any obvious problems like exposed wire, also check the sockets for the bulbs. Another idea i'd have is check all relevant fuses.
      10-28-2020, 03:19 PM   #3
Moab Bimmer
BMW Owner
Thanks for the response, around how much did the dealer charge you? If im unable to fix it at home i will probably take it in to be fixed.
      10-28-2020, 06:32 PM   #4
davidr3
448
Drives: 335i
Was warrantied. I also have both the outer lights for sale, in perfect condition with all bulbs if you'd wanna try replacing them as a whole.
Tags
f30, issues, tail lamp, taillights, trunk light
f30post
