BMW M2 Forum > BMW M2 Discussions > Vibration and resonance in cabin at 35-40mph
      10-27-2020, 04:48 PM   #1
Connors5453
Connors5453's Avatar
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Have a horrible vibration around 35-40mph, doesn't change with rpm or road conditions. Thinking it's either driveshaft related or maybe U- Joint? Any ideas?
Car goes into service in 2 days
      10-27-2020, 05:06 PM   #2
Anthony1s
756
Drives: 2018 Mineral Grey M2
Are you driving over the yellow road line?
Also, I'd delete this and post in the mechanical issues forum.
      10-27-2020, 05:07 PM   #3
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
No haha, happens on every road any condition, drive train maybe. Thanks I'll post there as well
      10-27-2020, 07:24 PM   #4
bimmer98
Drives: 2018 M2 Alpine White
2017 X3  [0.00]
2013 335i  [0.00]
1987 325is  [0.00]
My 2018 X3 just had the same symptom, soon after that developed the check engine light came on. Turned out to be a bad injector. Not the first time it's happened, same on my 135i a while back. Both times I thought the transmission was going to fall out or had a loose motor mount. Funny how the timing goes everything starts shaking.
      10-29-2020, 04:37 PM   #5
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Interesting! Mine doesn't
Change by rpm but could still explain it? I'll let my SA know!
      10-29-2020, 08:13 PM   #6
bimmer98
2017 X3  [0.00]
2013 335i  [0.00]
1987 325is  [0.00]
Injectors are usually progressive failures, vibrations would get increasingly worse. Come to think my X5 and VW Tiguan (x2) had injectors go bad too. I'm sure there are other failures that cause the same symptom. Loose mounts would cause that too.
All fixable stuff. Good luck!
      10-29-2020, 08:21 PM   #7
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
It has been getting worse! I'll tell my SA about this as well! Car is at dealer rn
      11-02-2020, 07:58 PM   #8
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Update*
Took to dealer and they replaced both front wheel bearings and said the problem is fixed!
Drove the car for 20 min and the noise is back!
Any guesses? Taking in to check alignment this weekend!
      11-03-2020, 07:55 PM   #9
bimmer98
2017 X3  [0.00]
2013 335i  [0.00]
1987 325is  [0.00]
Bad tire? Maybe when it warms up or maybe you lost a balancing weight. Hubs show signs if failure so they might have been bad too....or just a symptom of the real problem. I'm a hack mechanic btw. Nothing wrong getting new parts under warranty while they play trial and error.
      11-03-2020, 08:05 PM   #10
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
That's the plan! Good idea on tires, I'll take to big o and have them rebalanced if needed. Problem seems to get worse under braking now?
      11-04-2020, 12:21 AM   #11
smknjoe
smknjoe's Avatar
Drives: 2020 M2C, 2018 GTI, 2007 Rabbi
When I hear vibration under braking my mind automatically wanders straight to warped rotors. But what do I know? :
Usually happens if you overheat them.
Could also be a balance/tire problem or even a damaged wheel.
Did you smack a curb while tracking it?
      11-04-2020, 12:24 AM   #12
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Careful on track so no curbing but a warped rotor might be the issue! I'll check tomorrow!
      11-05-2020, 06:41 AM   #13
3t3p
New Zealand
455
Drives: M2
ah more warped rotors, here we go again. it's incredibly rare for rotors to actually warp
      11-10-2020, 06:22 PM   #14
bimmer98
2017 X3  [0.00]
2013 335i  [0.00]
1987 325is  [0.00]
Agree Probably not warped rotors. Dust deposits maybe.
      11-10-2020, 06:24 PM   #15
Connors5453
Drives: 2023 BMW M2
2023 BMW M2  [9.38]
Update: front left tire has a flat spot and a high spot on the other side..... going to replace soon
m2
