Tons of smoke coming from engine, ETA: rod smashed through piston :(
10-27-2020, 02:57 PM | #1 |
79
Rep 996
I am 99% sure I lost piston rings on cylinder 5.
29D1 - DME: Combustion misfires, cylinder 5. 2AAF - DME: Fuel pump, plausibility. 2D2E - DME: Throttle-valve angle - intake-manifold vacuum, correlation I had to stop due an accident on an interstate. Speed limit: 75. I punched it, I did not over rev it but I pushed it to 6k rpms. Misfire on cylinder 5 Tons of smoke, my car smokes like a smoke grenade. Besides rings, what else could cause so much oil to burn in a combustion chamber? 800 miles on the rebuilt motor. RPMs are also fluctuating. I saw this once before, problem corrected itself. I will check the vacuum line going to the intake. ETA: Bore scope video shows con rod where piston should be. Major mechanical damage. Its a hard pill to swallow but I am done with this car. Last edited by oilcrankinject; 10-28-2020 at 07:48 PM.. Reason: new info |
10-27-2020, 07:54 PM | #2 |
79
Rep 996
https://youtu.be/gJLGu544iu4
Bore scope video Spark plug from cylinder 5. Now it looks like I lost a valve or two. Timing is correct though. I am confused. |
10-27-2020, 10:36 PM | #5 |
1209
Rep 2,476
WTF...in the video it looks like you're missing a piston. As you pull the camera up you can see the top of the rod where the wrist pin is supposed to be connecting the piston to the rod.
It actually looks like you blew a giant hole in the piston and, what little remains of it, is down at the bottom of the cylinder bore. That engine is done for. |
IllSic_Design2124.00 |
10-28-2020, 01:07 AM | #9 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Ya but how did your vacuum line look??
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-28-2020, 01:30 AM | #10 | |
973
Rep 3,219
It looks like serious internal damage to the engine, exactly what stage tune/psi Were you running at just before this happened? |
10-28-2020, 06:45 AM | #11 |
79
Rep 996
I rebuilt it using the now the defunct newtis. I bought all of the special tools required...
Stock everything. Hell my turbos had shaft play but they still worked. I think I am done with my car. |
10-28-2020, 08:12 AM | #13 |
79
Rep 996
335xi_full_throttle30.00 |
10-28-2020, 11:06 AM | #14 |
2341
Rep 3,539
10-28-2020, 07:48 PM | #16 |
2685
Rep 4,202
Sorry op. What actually went wrong from your rebuild though?
10-28-2020, 07:49 PM | #17 |
79
Rep 996
