10-26-2020, 03:41 PM | #1 |
372
Rep 622
Calling on Manual Transmission Experts
After installing a clutch stop and doing the CVD delete I'm pretty happy with the feel. The only minor gripe I have left is the relatively light clutch. It feels lighter than I remember others and I prefer one with just a little more heft (nothing drastic). So my question is...can heft be increased via clutch pedal springs or does heft primarily come from the pressure plate springs? I'm not going to change clutch components for a minor change in feel but I if can get some more heft via pedal springs, please point me in the right direction.
10-26-2020, 03:50 PM | #2 |
1103
Rep 1,263
Drives: 20 BMW M2C 17 Mazda MX-5 RF
There are several threads on the Ultimate Clutch Pedal (UCP) and the Auto Solutions Short Shifter.
Both are outstanding mods.. https://f87.bimmerpost.com/forums/sh...&highlight=ucp https://f87.bimmerpost.com/forums/sh...&highlight=ucp https://f87.bimmerpost.com/forums/sh...&highlight=ucp
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 |
10-26-2020, 05:55 PM | #3 | |
372
Rep 622
10-26-2020, 09:01 PM | #4 |
5556
Rep 5,372
You want less springs. The stock clutch pedal has two springs, one within the other. Removing the outer most spring will increase weight quite a bit and removing both, more so. Removing both though creates some lateral instability with the stock clutch pedal. Unfortunately, the only real way to get the springs out (more importantly back in) is to nearly remove the pedal. When you're at that point, you might as well replace with the Ultimate Clutch Pedal which is light years better than the OEM pedal. The UCP can easily handle no springs. I've had the pedal for a few years now.
10-27-2020, 07:24 AM | #5 | |
372
Rep 622
11-05-2020, 09:00 AM | #6 |
RIP E39
37
Rep 30
I removed my assist springs with little fuss. Just had to drop down the panel/knee bolster and popped out the whole spring assembly. Yes, there is a slight increase in the lateral movement, but I think the increased feel/weight is worth it. Honestly it didn't give me as much weight as I wanted. I also did the CDV delete and love it. I may upgrade to the UCP someday, but I'm okay with the current set up for now.
Gizmo 335i371.50 |
11-05-2020, 10:30 AM | #7 |
986
Rep 1,153
UCP + good SSK + CDV delete transforms the MT experience in these cars...
Gizmo 335i371.50 |
