F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > will this headlight fit on US spec car?
Extreme Powerhouse
      10-23-2020, 10:32 AM   #1
p0x6
Drives: 2016 BMW 328i
Hey forum!
first post hopefully it hasn’t been asked before.
Do you know if this euro? spec f30 headlight fit on a US spec f30?
if so, any benefits?
      10-23-2020, 05:08 PM   #2
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
My understanding is that the headlight units themselves should fit in your chassis without issue. However I believe that UK headlights (or anywhere cars are right-hand drive) have different hardware configurations that align and shape the lights for driving on the other side of the road, and this cannot be addressed by coding.
That being said, euro adaptive headlights are sought after as the US LCI adaptive headlights do not support non-glare highbeam functionality due to a hardware limitation. Pre-LCI US adaptive LED headlights are the only US headlight that can support true non-glare highbeams by making coding changes.
Someone correct me if I'm wrong.
p0x60.00
      10-23-2020, 05:25 PM   #3
p0x6
ah, so the lights that i posted are UK lights. not EU lights? I think 7453484-01 would be the UK versions right?
      10-23-2020, 05:32 PM   #4
psyki
E36fiend
2014 X5  [0.00]
I didn't mean to imply the headlights in your picture are from the UK (I have no idea if they are or how to tell), I was just pointing out something to be aware of. You don't want right-hand drive (RHD) headlights if you drive in the US.
      10-23-2020, 05:35 PM   #5
p0x6
haha got it
would non AFS euro LED lights be basically the same as US non AFS lights since it doesn't have the desired non-glare highbeam functionality that euro LCI adaptive lights do?
      10-23-2020, 05:55 PM   #6
psyki
E36fiend
2014 X5  [0.00]
haha got it
I believe so but I am not 100% sure. My understanding is that any differences (apart from the adaptive stuff and RHD) are controlled by coding parameters, for example whether the amber corner lights turn on with the headlights.
You may need to code these headlights after installing them, even if they are non-adaptive you might get errors or certain functionality may not work right.
What exactly is your intention? Are you just replacing a broken headlight? Or looking for some kind of upgrade?
      10-23-2020, 05:58 PM   #7
p0x6
i'm looking to either replace or upgrade. trying to understand which one i should get and if there's any pros to upgrading to like a euro one.
      10-23-2020, 06:13 PM   #8
psyki
E36fiend
2014 X5  [0.00]
As far as I'm concerned the only reason one would choose Euro headlights over US is if you wanted non-glare highbeam (NGHB) functionality, and did not already have pre-LCI US adaptive LED headlights. I don't think there were any other differences.
BTW NGHB are very cool
      10-23-2020, 06:25 PM   #9
p0x6
thanks! super helpful. but if i'm looking for just a replacement and the EU version is cheaper, it's still ok to buy. And with some coding should work fine?
      10-23-2020, 06:33 PM   #10
psyki
E36fiend
2014 X5  [0.00]
I believe so but I'm not 100% positive. Just don't blame me if something doesn't work
      10-23-2020, 07:39 PM   #11
BimR
245
Drives: 2016 328
If I may, how much cheaper should they be to make the coding issues worth it? I'm NOT casting doubt ajd maybe this is super simple but unless the savings are huge, I tend not to add another wrinkle to the mix. But I'm a scaredy kitty 😜
      10-24-2020, 11:56 PM   #12
p0x6
i'm currently looking at a pair of them for like $400. all tabs are good. its like $400 each on ebay for the US ones, so saving 50%. i think that's pretty good, right haha?
      10-25-2020, 07:45 AM   #13
BimR
245
Drives: 2016 328
That's worth trying. I don't know if it will work but definitely worth it!
      10-25-2020, 06:31 PM   #14
smrtypants44
smrtypants44's Avatar
Drives: 2017 440i
ECE headlights have a different cutoff fyi.
Technically these lights are not legal to be on your car because they wouldnt have the US sidemarker light on them but its doubtful anything would happen.
Poochie9104.50
      10-25-2020, 07:04 PM   #15
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
[IMG]https://i.ibb.co/ryf8W0w/dotece.jpg[/IMG]
Good stuff, you mind if sharing the source of that beam layout.. Thanx.
f30post
