Could it be my HPFP?
10-21-2020, 11:46 AM | #1 |
SwedishWoodChopper
Rep 21
I have a 2008 335i E90 pretty stock for the most part, JB4 running backend flash mode map 2 (targeting 17psi, not the brightest move, but she takes it), MHD backend flash, VRSF DP's, tial bov, alpina B3 trans flash for my auto trans.
I've been noticing over the past few months when ever I open up on the highway to do a pull, my engine will start misfiring and sputtering like crazy, sometimes it'll even go into limp mode, I read the BMW codes via the JB4 dash readout and have pulled a "29DC" code "Cylinder Injection Cut Off, Fuel Level Too Low" which makes me think it's a flow issue, because this issue occurs even after I've filled up, full tank, 3/4 tank, 1/2 tank, she throws the same code. I was able to run a 2sec interval log thru the JB4 interface, and noticed my high pressure fuel was slightly going down when I was doing a pull, the low pressure fuel log went down when high pressure went up, I assume from the high pressure side drawing in fuel, and then when the high pressure side went down, the low pressure fuel was on the high side of its pressure range. Basically the low pressure fuel ran from 57-77psi, which everything I've seen on all the forums says is pretty normal, but the high pressure fuel dipped below is operation range close to the peak of the RPM's during that pull, meaning, when I got close to my top logged RPM during the pull, the high pressure fuel started shitting it's pants and then came back on, at one point it even reached 2,700psi, but when it dipped it was only putting out 1,200-1,350psi. Basically, could this be my HPFP going? Or is it something else like injectors or the LPFP? |
10-21-2020, 02:26 PM | #3 |
449
Rep 823
Yeah, if you're seeing your rail pressure drop to 1200 PSI while your LPFP pressure is above 50 PSI, it's pretty safe to say your HPFP is on its last leg and needs replacement.
2008 335xi 6MT - 16T China Turbskies - eBay FMIC, DP & CP - VRSF Inlets - SSR DCI's - Walbro 450 LPFP - RFP e85 Tune
10-21-2020, 03:01 PM | #4 |
SwedishWoodChopper
Rep 21
Yuckers, I just pulled the trigger on buying it, luckily FCP Euro has a sale going and they sent me a coupon a day or so ago. But ya, I was seeing less than 1500 on the rail. Thank you for the reply, I'll keep you both posted with the results as soon as I'm back up and running.
10-21-2020, 03:05 PM | #5 |
SwedishWoodChopper
Rep 21
It's the pits, I just ordered a new one from FCP Euro, so we'll see, but you must be having a sweet time with the 6062, I wanted to go twin MMP, or Vargas, but my buddy who has an 09 335i went thru 2 or 3 sets of Vargas twins, they were warrantied so he didn't shell out each time, but I saw that and heard about MMP's exploding and was like, uhhh.... yikes!!! Single turbo it is.
10-21-2020, 04:16 PM | #6 | |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-21-2020, 04:19 PM | #7 | ||
SwedishWoodChopper
Rep 21
10-21-2020, 04:38 PM | #8 |
2685
Rep 4,202
Ya for sure, they've had the sale going for a few days now. Are you getting any sensors to go along with it?
10-22-2020, 08:02 AM | #9 | |
67
Rep 128
10-22-2020, 10:39 AM | #10 | |
973
Rep 3,219
10-22-2020, 10:56 AM | #11 | ||
SwedishWoodChopper
Rep 21
10-22-2020, 01:05 PM | #12 | |
973
Rep 3,219
10-22-2020, 04:03 PM | #13 |
Chelsea Football Club
345
Rep 780
Just had the same issue. It's your HPFP. Did you also get weird start up fluctuations. Also check to see what your rail pressure was at idle. Mine was skipping all over the place for a week before I had that same highway misfire trying to do a pull.
