BMW 2-Series Gran Coupe
BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      10-19-2020, 04:31 PM   #1
J-RO
2094
Drives: BMW M240ix
Tire Pressure
My M235i came with Pirelli Cinturato P7 P225/40 R18 all season run flat tires . The door jam sticker states the recommended tire pressure is 39lbs. My prior 4 series and my wife's X3 with the same tires recommends 35 lbs. The ride is a bit rough. I assume the door jam sticker is correct. Is anyone running 39lbs in their tires? Thanks.
      10-19-2020, 11:20 PM   #2
lilstevie
89
Drives: BMW i5
IDrive will show you the recommended pressure if you have the tpms setup based on your tyre and loading. My 218 with its 235/35r19 p zero 4 non-rft’s the recommended pressures are 37psi front 32psi rear
      10-20-2020, 05:24 AM   #3
J-RO
2094
Drives: BMW M240ix
Thanks. I will check that out.
      10-28-2020, 02:54 PM   #4
LuCanBimmer
12
Drives: M235i GC
My door jam sticker based on the factory 235/35/19 tires, recommends 41psi front & rear.
      10-29-2020, 09:20 AM   #5
J-RO
2094
Drives: BMW M240ix
I lowered mine to 37 psi. Rides much better.
bmw
