MHD N54 Low Boost Target / Timing Pulls? (Logs Attatched)
10-19-2020, 12:48 PM | #1 |
Rep 42
Hi all, just replaced my valve cover (cracked) yesterday and thought I'd do a pull and log to make sure everything is okay.
In the log (2nd-3rd-4th gear), I noticed the boost target is only really ever around 13psi, which is level the whole rpm range. Boost is hitting target no problem. I also noticed a minor correction in second gear, but during the pull in fourth gear, all cylinders had some major corrections. WGDC looks good to me but those who know more can evaluate. can anyone advise what could be the cause of this? I thought mhd stage 1 should be targeting around 15 - 16 PSI. Plugs, coils, injectors have about 5k miles. Thanks https://datazap.me/u/apex6589/stg1-v...&data=3-16 |
10-19-2020, 04:04 PM | #3 | |
973
Rep 3,219
You'll get about 13-14 psi based on the map version you run. So your targeting the correct psi and your boost levels are fine. Your timing corrections could be related to your plugs and/coils. Before you go changing them, try running V7.1 or V9 maps and logging again. V8 maps have been reported by several people to have issues. Last edited by Saif2018; 10-19-2020 at 04:34 PM.. |
10-19-2020, 04:14 PM | #4 |
Rep 42
10-19-2020, 04:30 PM | #5 | |
973
Rep 3,219
10-19-2020, 04:57 PM | #6 | ||
Rep 42
10-19-2020, 04:58 PM | #7 | ||
Rep 42
10-19-2020, 05:29 PM | #8 | |
Rep 42
10-19-2020, 06:27 PM | #9 |
Rep 42
Another thing is I've heard of some forum members having bad timing corrections with winter blends of gas, even 93OCT, which is what I'm on now in CT I believe. I'll run V9.0 logs and if I still have it run V9.0 91OCT and see if they're any better.
10-19-2020, 08:30 PM | #10 |
Rep 42
So I flashed 93oct V9.0 and did two logs as MHD asks (2500RPM in 3rd, pull until 3-4s in 4th), and everything looks good in third (with one cylinder timing hitting -3.3, kind of high? and then tapering and in the second log another matching it), but then as soon as I shift to 4th all cylinders experience heavy corrections, ranging from 0 all the way upto -6.3.
I also read that it takes a few days for the DME to adapt to the fuel, your car, etc with ots tunes like this, these logs were right after a flash / knock adaptation reset. Any ideas on the corrections after shifting? Logs: https://datazap.me/u/apex6589/mhd-st...-6-7-8-9-10-18 https://datazap.me/u/apex6589/mhd-st...-9-10-15-16-18 |
10-20-2020, 01:48 AM | #12 | |
973
Rep 3,219
Yes DME does take a while to adapt, I can see your IAT's rapidly climbing due to stock intercooler heatsoak , that would also contribute to timing corrections, Timing corrections are normally a result of bad fuel, plugs, coils, Intercooler heatsoaking. Would recommend changing coils and plugs, (use Eldor coils or failing that Delphi ones, OEM Bosch plugs should be fine) next step would be FMIC upgrade. In the meantime you can try v7.1, which should have slightly less timing and boost. Last edited by Saif2018; 10-20-2020 at 01:59 AM.. |
10-20-2020, 08:35 AM | #13 | ||
Rep 42
10-20-2020, 10:28 AM | #14 | |
973
Rep 3,219
If you had a log in summer vs winter fuel that would help identify if this is the case. OEM Bosch coils can be the culprits though, Delphi or Eldor Coils seem to run better when tuned. |
