F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Multiple Errors Codes
Extreme Powerhouse
      10-18-2020, 09:30 AM   #1
i128
i128's Avatar
316
Drives: 340iX (6MT) - X3///M40i
Question Multiple Errors Codes
Hi,
Upon start up, I noticed multiple error codes (see picture).
However I've verified all everything physically, and all seem OK.
Tried unplugging the battery method, but unfortunately all it did was reset the clock.
Any ideas? - the car is a 2016 F30 328i -
(I don't even have the lane departure feature...)
Thanks!
      10-18-2020, 10:47 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The only way to find out what's going on is with an OBD diagnostic tool. For basic diagnosis and code clearing Bimmer-tool Lite freeware works surprisingly well.
i128316.00
      10-18-2020, 10:56 AM   #3
i128
i128's Avatar
316
I'll eventually look into doing some coding as well in the future.
What Bluetooth OBD2 dongle would you recommend?
      10-18-2020, 01:19 PM   #4
davidr3
448
Drives: 335i
Battery may be going bad IMO, but it's a 2016 so it may not be. I personally use Veepeak OBDCheck BLE+ for the OBD 2
Bimmerlink to read codes + check battery life.
i128316.00
      10-18-2020, 02:47 PM   #5
Phoenix704
Phoenix704's Avatar
87
Drives: 2014 328i
+1 for Veepeek. If they all appeared at the same time, i'd be suspect of something electrical. Clear the codes, then have your battery and alternator tested.
i128316.00
      10-18-2020, 03:09 PM   #6
rak299
Drives: 2021 M3 6MT
How old is your battery?
      10-19-2020, 01:06 PM   #7
i128
i128's Avatar
316
it's the OE one, 2016.
      10-19-2020, 03:31 PM   #8
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
You maybe should check your voltage with the car's cluster display if you don't have a multimeter? Should be 12.5-ish when off and 14V when on.
I replaced my OE battery (same year as you) when I got it--was getting a low bat message though--you recall getting any warnings like that?
I'd get something to read and clear codes (as mentioned) or trips to guys with scanners is going to get expensive for you.
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
      10-20-2020, 09:50 PM   #9
i128
i128's Avatar
316
So to verify/clear the error codes, will I need bimmercode or bimmerlink?
Or is there another app, (ideally free) that will help me do this?
      10-21-2020, 01:07 AM   #10
davidr3
448
Drives: 335i
Bimmerlink, check battery, check codes, clear codes
i128316.00
      10-21-2020, 07:01 AM   #11
Billfitz
Billfitz's Avatar
Go back and read Post #2 again.
      10-21-2020, 07:16 AM   #12
i128
i128's Avatar
316
Thanks, is it only Android based?
      02-18-2021, 10:57 AM   #13
i128
i128's Avatar
316
Overdue update: unfortunately none of the downloaded apps helped the situation.
The car was taken to the dealer, too bad warranty was up...so 24hrs stay, + $400 later...
ECU reset and software update installed.
f30post
