F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 435i not running
Studio RSR
      10-18-2020, 04:29 AM   #1
Jaynoel32
Drives: bmw 435i gran coupe
435i not running
I bought a BMW 435i from the auction. I had the car on for a little bit in my driveway until it just started shaking then it turn off. I can not turn it on it just cranks. Fuel pump, fuel lines, compression, starter and alternator is good. I checked ISTA and the pictures show the codes I get, I understand the car is missing airbags and seatbelts so I know some of those codes are caused from that but does anyone recognizes theses codes? Would anyone of theses codes stop the car from running?
      10-18-2020, 08:00 AM   #2
njdangelo
njdangelo's Avatar
436
Drives: 2019 x5 50i
Still sounds like a fuel delivery problem to me. When you open the driver door do you hear the in take fuel pump prime? There are two in the car, the hpfp in the engine compartment and the lpfp. Which one did you test as good and how did you test it? Continuity?
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten.
      10-18-2020, 08:07 AM   #3
BMWILUVU
809
Drives: 340ix
First easy step is check all the fuses for this car.
      10-18-2020, 08:53 AM   #4
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
It looks like there are several codes about the alarm. If the car thinks it has been broken into it will not allow it to start. I don't understand how this all works, so maybe someone who does will chime in.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg
2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
      10-18-2020, 08:38 PM   #5
Jaynoel32
After removing off the back seat and fuel pump covering I seen gas pumping out of the fuel pump and when I opened the fuel rail on the engine compartment the gas sprayed out at a high rate and I even removed the spark plug and it was wet with gas on it.
      10-20-2020, 06:42 PM   #6
pshovest
BMW CCA 69606
86
Drives: '15 435i,'10 535i,'08 X5,'98M3
Air bag deployment usually causes crash module to disable the EKPS and remove power from the LPFP. It also severs the + battery cable, the BST, with an explosive charge.
Was the EKPS code(s) previously cleared? I'm thinking it was since you seem to have fuel pressure.
You've got (6) ignition circuit errors for air bags & BST. Has the BST cable been replaced? The 930992 code may mean the BST is still defective.
Are there more codes below the last one? The right side scroll bar isn't quite at the bottom.
Plugs are wet, do you have a spark?
      10-20-2020, 09:06 PM   #7
Jaynoel32
Hello, Pshovest
Their was EKPS codes that was cleared, the new BST cable will arriving tomorrow so I will definitely change it . How exactly do you test for LPFP I thought if you heard it prime it was good. Their are no more codes I just ran a test through ISTA and it was just showing up at the bottom. I don't have spark, we tried putting in gas in the intake to start it and it did not work?
      12-19-2021, 04:39 PM   #8
alexmyhas
alexmyhas's Avatar
Drives: Bmw 435i xdrive
same problem!
Originally Posted by Jaynoel32 View Post
Hello, Pshovest
Hey, i bought a 435i and have the exact same issue! did u get it figured out? mine cranks super good and has pressure in the lines with fuel it just does not want to start.
      12-19-2021, 05:40 PM   #9
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Jaynoel32, by any chance do you know if your 435 experienced water damage?
      12-19-2021, 05:58 PM   #10
alexmyhas
alexmyhas's Avatar
Help!
Hey i have the exact same issue as (jaynoel32) my bmw 435i cranks but no start and i bought it at auction. No airbags have been blown. There is no water damage anywhere aswell, do you have any ideas on what this can be?
f30post
