10-17-2020, 09:03 PM | #1 |
147
Rep 266
Issue getting N55 water pump bolts back in
I just installed MST V2, turbosmart diverted valve, MST boost pipe and while trying to bolt the water pump back in, the screws seem short? I'm having a hard time getting the bolt to thread into the holes. It's almost like the rubber grommets in the water pump brackets expanded. Anyone else experience this before? Any tips to get the water pump bolted back on?
10-18-2020, 03:43 PM | #2 | |
7292
Rep 7,460
Also make sure the bolt holes on the water pump brackets are clean and coolant free, dried coolant can becomes like hard water deposits and make it hard to thread the bolts back in, but if the holes are clean they should be able to be hand thread back in.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
tenkies147.00 |
10-19-2020, 01:45 PM | #3 |
147
Rep 266
Thanks. I figure out what my issue was and it was because I was tired and trying to bolt the pump back into the wrong holes. Tried to bolt it back into the bracket to engine block holes below the actual bracket holes. all good now. Thanks
