Boost Leak from BMS charge pipe.
10-17-2020, 08:07 PM | #1 |
17
Rep 147
Did a boost leak test and realized I'm leaking boost from the charge pipe connecting to the tb. Anything above mhd stage 1 throws the car into limp mode. I'm running the oem charge pipe gasket. Any recommendations? Thanks for looking!
10-17-2020, 09:59 PM | #4 |
17
Rep 147
10-17-2020, 10:07 PM | #5 |
17
Rep 147
I guess I'll try that. I might just change the entire charge pipe to the ones with the silicone hoses with clamps. Or if I could get a silicone hose to fit over the connections. What charge pipe are you running? How much boost are you making?
10-18-2020, 12:08 PM | #6 |
720
Rep 946
My vrsf chargepipe connects the same way without any issues. Id contact bms and see if they have any ideas
I’m running 20psi btw
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
billowusu16.50 |
10-19-2020, 09:11 AM | #8 |
58
Rep 288
I just looked on their site and it doesn't mention that they are bigger just heavy duty.....
The usual mods....
10-19-2020, 09:14 AM | #9 |
BimmerPost Supporting Vendor
24201
Rep 190,807
Replacing the O-ring should fix this issue
10-19-2020, 04:03 PM | #10 |
58
Rep 288
Does the pipe move any if you try to wiggle it?
The usual mods....
10-19-2020, 04:09 PM | #11 | |
17
Rep 147
10-20-2020, 07:42 AM | #12 |
58
Rep 288
Ok thanks!!!
The usual mods....
10-22-2020, 05:42 PM | #13 | |
17
Rep 147
IllSic_Design2124.00 1Bad335turbopsi57.50 |
10-23-2020, 07:22 AM | #14 |
58
Rep 288
Where did you get the new o-ring from?
The usual mods....
10-23-2020, 11:34 AM | #15 | |
17
Rep 147
Boost Monkey CHARGE PIPE Replacement O-ring for BMW N54 N55 335i Z4 535i 535xi 335xi 335is 135i CP https://www.amazon.com/dp/B0787RYXC2...UTF8&psc=1 |
10-23-2020, 12:39 PM | #16 | |
58
Rep 288
The usual mods....
billowusu16.50 |
10-23-2020, 03:07 PM | #17 |
27
Rep 64
This might sound a little weird, but I've heard of people having issues installing charge pipes over this o-ring. Struggling with it can possibly damage or stretch it.
Typically, if you freeze an o-ring then apply a thin amount of pet (vaseline) to it right before install, it can make installation easier. The smoother the install, the less chance of damage. Freezing the o-ring will shrink it which limits interference during install. You just have to be gentle with it while putting around the TB. |
10-23-2020, 03:26 PM | #18 | |
17
Rep 147
10-23-2020, 04:40 PM | #20 |
27
Rep 64
In aviation maintenance we use a similar item called 'Pet' (petroleum) but I don't recommend cross functional use with the aviation grade stuff.
