F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F36 cranks not start
ARMA SPEED
      10-17-2020, 06:14 PM   #1
Jaynoel32
Drives: bmw 435i gran coupe
Hello, I have a BMW 435i gran coupe. Stated the car in my driveway when all of a sudden it just turned off. Tried to start it back up but car just cranks. I checked compression, fuel pump, fuel lines, starter, alternator all works. Tried to jump start car it does not work. Tried ISTA +, I get the codes:
ABL System analysis- CAN/FLexRay/Ethernet: Physical bus fault , I then clicked show symptoms: DE8C5E LIN SINE communications fault
ABL Alarm system interior movement detector I then clicked show symptoms:
DWA alarm activations
801A52 SINE: Fault when adjusting coding data
ABL Alarm system interior movement detector, I then clicked show symptoms:
Interior movement detector sensor
Siren with tilt alarm sensor
ABL ACSM: Ignition circuits
Also get code 930992 Safety battery terminal: Short circuit to B+
      10-18-2020, 03:33 PM   #2
Elvisfan
516
Drives: 2018 430ix convertible MGM
It’s broken.
      10-18-2020, 06:33 PM   #3
Jaynoel32
Originally Posted by Elvisfan View Post
It’s broken.
I know 😭
      10-18-2020, 09:00 PM   #4
Elvisfan
516
Originally Posted by Jaynoel32 View Post
I know 😭
I just saw your other post.
      10-19-2020, 04:04 AM   #5
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
Could be many things...try another key or hold yours close to steering wheel in the spot made for when the battery in it is low.
The B+ terminal, I believe, is the terminal you'd hook up the + cable to when jump starting--make sure it's tight and clean--and even though you just started the car, check the voltage.
I'm not an expert on our security system, but it sounds like your car thought it was broken into and 'maybe' deactivated something--but that all might have been triggered by low voltage...which might be low voltage or a loose/broken/corroded connection somewhere in the electrical system.
...good luck...and a bump!
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
      10-19-2020, 06:58 PM   #6
Jaynoel32
Thank you I will look in it
      05-25-2021, 07:58 AM   #7
loknar28
loknar28's Avatar
Drives: 2014 BMW 535i XDrive
Did you ever figure out what the problem was with your alarm? I am having the same issue. Replaced the Siren/Tilt unit and still doesn't work. Still showing ista+ 801A52 SINE: fault when adjusting coding data.
      12-20-2021, 01:38 PM   #8
alexmyhas
alexmyhas's Avatar
Drives: Bmw 435i xdrive
Same prooblem!
Hey did you end up figuring it out? my car cranks but no start
f30post
