F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Call stalled, rpm jerk when going into gear - 2013 F30 328i
Extreme Powerhouse
      10-15-2020, 09:02 PM   #1
slof30
Drives: 2013 328i xDrive
Hello.
Yesterday, I noticed the car's rpms being a little wonky and some jerking when coming to a stop. I pulled over and looked under my hood to notice my intake was off of the actual air intake. The clamp was extremely lose, so I tightened it back up and put the hose back in place and everything was fine. Drove about 10 miles to work, then back home.
Today, I had to go somewhere so when I put the car into reverse, the RPM's jerked down below 500 then back up to the normal position they're usually at (about 800), but the car drove fine. I came back home and let the car sit for about an hour. I started the car again, let it warm up for a few minutes, then I put it into drive (didn't press on the gas at all), let it roll and it stalled. I immediately turned the car off, opened the hood, checked the intake clamp and hose both of which were intact. Nothing was lose. I re-secured the clamp but untighting it and retighting it, and tried again. When I put it into drive the RPMs again jerked down below 500 then back up. I haven't attempted to drive the car because I'm not sure what the issue is and don't want to risk damaging the engine.
Any help would be greatly appreciated
      10-16-2020, 08:07 AM   #2
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
Try pulling the codes.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg
2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
      10-19-2020, 11:37 PM   #3
WeDclOwN
27
Drives: x3 m40
Had the same problem with my old 428, would almost stall when cold. Did you have injen intakes
f30post
