10-15-2020, 11:28 AM | #1 |
265
Rep 720
Reasonable cost for carbon pro spoiler install
Can anyone tell me what would be a reasonable cost to have the dealer install the carbon pro spoiler, outside the sale of the car? The one I am buying has the standard spoiler on it (M5C), and I want to upgrade to the higher profile spoiler.
10-15-2020, 11:35 AM | #2 | |
26
Rep 142
Edit: As far as cost of spoiler, I'm finding the OEM pro spoiler for $648 online. Hope this helps |
10-15-2020, 12:16 PM | #3 | |
265
Rep 720
What about removing a pre-existing one and replacing it with the pro? Still just 1 hour? Last edited by ///WeissBisBlau; 10-15-2020 at 12:27 PM.. |
10-15-2020, 12:31 PM | #4 | ||
26
Rep 142
Yes I have done it on my wife's F80 M3, and I plan on doing it to my F90 M5 that I just picked up. The longest part is removing the old adhesive, for which I've found a heat gun and 3M auto adhesive remover and some old micro fibers to work best |
10-16-2020, 12:22 AM | #5 | |||
1658
Rep 1,536
To the Op: About F90 spoiler, I'd say it takes a good 1.5-2hours. If you are planing to use OEM Pro spoiler, that one gets mounted with Betalink, as the cavity is too deep for double sided tape. Betalink needs to be applied carefully so it doesn't become a huge mess, and it is time consuming. Once finished and the betalink settles, the spoiler gap is less 1-2mm and looks as it is almost moulded to the trunk. I love it! |
freshxdough3509.00 |
10-19-2020, 07:01 PM | #6 |
377
Rep 541
I installed the carbon pro spoiler at a BMW dealer, they charged me 1 hour labor on the dot (includes removing the original tiny ass lip spoiler). I really wouldn't do this procedure myself cause in some other thread they say apparently the coverage of the original spoiler is different from the carbon pro so if you screw up removing the adhesive etc. from the original spoiler it can be exposed as the shape of the pro spoiler is different. Don't forget to order the betalink.
10-19-2020, 07:13 PM | #7 |
162
Rep 329
I did this on my first f90 - taking the old spoiler off as others have said is the hard part. It will leave your paint discolored - at least it did for me and a few others a few years back.
The Betalink on the original spoiler leaves a discoloration that isn't the worst thing in the world but if you look it will be there. The positioning is different, the new spoiler sits on the edge of the trunk and the old one sits on the top. The new one is fairly easy to put on and just keep it taped down with some painters tape overnight and it's good to go. |
10-24-2020, 10:23 AM | #8 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
You don't need to use betalink although I recommend it. I used normal 2 sided 3m with no issues. It is a but deeper of a pocket but it is slightly flexible so when I put it on I first activated the tape with a heat gun and then pressed down firmly for a few seconds e during the tape makes as much contact as possible. Been on 4 months with no issues yet. Fingers crossed.
And yes removing betalink is a bitch. Ended up leaving a bit of damage to the clear coat that I had fixed before being ceramic coated. Luckily the car is DG so you can't even tell any more.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wifes now) |
10-25-2020, 06:31 PM | #9 |
43
Rep 125
Just re install mine from m550 to m5 easy , use double tape 3M VHB #5952 Dual Sides Acrylic Foam Tape , 1 inch on the sides / 0.5 inch in the middle section after removing from m550 notice that middle section ( was not making contact with the trunk ) require double layer in order to attached properly, also use adhesive prepare , to remove old tape use
Decal Eraser Removal Wheel Kit w/ Power Drill Arbor Adapter 3.5"Rubber Pinstripe $7.89 ebay special . So much fun to do that and is holding great . All job about an hour. |
10-27-2020, 11:40 PM | #10 |
265
Rep 720
OK, so wound up just going with a dealer install, as they did it while I was out of town, and I just wanted to pick it up ready to go. At first, it looked ok, but tonight after I got in from a (very fun) little drive, I was playing around with it, found it to be a little bit loose, and then saw one side of it looking like this:
If I press down on it, it will go down, but will obviously come right back up. If I could leave something attached to it, maybe it would hold it down? Otherwise, any ideas as to how to remedy this? The dealership is about 2.5 (inconvenient) hrs away, so taking it back, for this, is sort of not in play. Open to suggestions? Last edited by ///WeissBisBlau; 10-27-2020 at 11:44 PM.. Reason: Added photo |
10-28-2020, 04:25 AM | #11 | |
26
Rep 142
10-28-2020, 12:17 PM | #12 | |
377
Rep 541
10-28-2020, 05:32 PM | #14 | |
1658
Rep 1,536
If it is betalink, then whoever did the install, didn't do a proper prep job. Either way, take it back. It is not supposed to happen. Mines on with Betalink, and it is ROCK solid. I can't even imagine how I'm going to remove it in the future, that's how solid it is |
10-29-2020, 09:07 AM | #15 | |
12965
Rep 18,712
You will need Betalink to install the Pro spoiler. I have installed many of them and no other way but Betalink. Unfortunately I don't have pictures since I have to hold them up in place with tapes for 48 hours before it is fully cured.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
