10-13-2020, 01:43 PM | #1 |
336
Rep 365
F30 rear license plate vibration sound when trunk/boot is shut.
Wanted to inquire if anyone else noticed this. The trunk has a nice thump to it when it is being shut closed. However, I noticed the license plate on the trunk produces a sort of vibration like sound when trunk it slammed shut, almost like a hollow rattle that takes away from the nice thump. If I close my trunk while touching the plate, it sounds beautiful. I tried removing the license plate and tightening the plastic US holder bracket and that vibration sound is gone for a month or two, but over the course of driving seems to loosen itself and starts to make that sound again. Wondering if anyone found a way to make it sound more solid long term? I am considering retrofitting power boot so that will eliminate the high intensity thump vibration since the closing will almost become soft close, but until then this is the only complaint I have not been able to resolve. Any feedback is greatly appreciated.
10-13-2020, 02:04 PM | #2 |
214
Rep 496
I think the problem should be very simply sorted by firmly securing the license plate, and only you or someone who can actually observe how the plate is currently held and think of a better way to secure it. I don't think anyone here on the net can work out the problem better than you can (because we can't see what you see). Good luck!
10-13-2020, 02:18 PM | #3 |
549
Rep 384
They make little rubber/foam washers that go between plate and the holder, that will eliminate most of the vibration.
If the whole bracket is loose, try adding thread-locker to the holder bracket screws. |
