10-13-2020, 09:18 AM | #1 |
14
Rep 53
F32 440i Tyre Sizes
I currently own a 2017 440i Coupe, my current tyre sizes on the 442m 19" wheels are:
Front 225/40/R19 Rear 255/35/R19 What would be the best tyre sizes to get? Thanks in advance |
10-13-2020, 10:49 AM | #2 |
277
Rep 833
Drives: BMW F36, E36, E93
Is there a problem with your tire size?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
10-13-2020, 12:10 PM | #3 |
549
Rep 384
255 is already the largest width that some chain tire shops will put on a 8.5" wheel. That said, 275/30 will usually fit on a 8.5 safely, and 235/35 on the fronts will give you equal diameter.
10-13-2020, 01:22 PM | #4 |
14
Rep 53
10-13-2020, 02:15 PM | #5 |
549
Rep 384
Depends how hard you drive and if you're experiencing wheel spin and/or under steer with the stock sizes. If you're driving at the limit you'll have a bit more traction at the front during turn in, and better hookup at the rear.
For normal driving, no benefit at all, plus increased costs of tires at those sizes. |
10-13-2020, 02:24 PM | #6 |
214
Rep 496
People consider changing tyre size usually because they change to different wheels. In your case, the justification usually is just for the looks (I'm not sure if this is what you're after).
10-14-2020, 12:34 AM | #7 |
3080
Rep 4,330
255/35/19 is the max width for 19x8.5" rear, so leave it.
swap the 225/40/19 up front, to 245/35/19, to reduce understeer. here are some pics of the said swap. |
10-14-2020, 02:45 AM | #8 |
277
Rep 833
Wider tires always benefit the traction, but I'm still not sure what you are after?
For someone not pushing the car, you got exatly the right tires
Such Fun
11-10-2020, 08:48 PM | #11 |
271
Rep 495
According to an actual race car driver, your tire should 0.5" narrower than your wheel size.
https://motoiq.com/how-to-properly-s...r-performance/ You need to match this measurement: |
