10-13-2020, 05:42 AM | #1 |
135
Rep 457
Battery charging
How do you guys charge your 12v battery if you have to? My parking space (underground car park below flats) doesn't have any plugs nearby so I would have to take the battery out and charge it at home. However, since the boot is released electrically, what's the normal process? Lock the vehicle before disconnecting the battery and just the leave the boot open? Or close the boot afterwards and then either connect the charged battery to the terminal in the engine bay using cables or try to release the boot latch from inside?
10-13-2020, 05:58 AM | #2 |
417
Rep 919
The key part of our key should get you into the car okay after you remove the battery, and supplying power through the hood terminals 'should' get the trunk open...maybe leave the back seats down just in case?
I wouldn't leave my trunk open in a public space, but I live in a country of lawlessness with millions of illegal baby immigrants running around murdering us and stealing our ballots, so the UK is probably much safer for your car.
10-13-2020, 07:22 AM | #3 | |
245
Rep 500
10-13-2020, 07:57 AM | #5 | |
417
Rep 919
Technically, it isn't a new battery, so registering it as such 'might' cause the car to slightly undercharge it, but honestly, I don't know.
10-13-2020, 12:43 PM | #6 |
772
Rep 1,502
No, there’s a battery sensor that monitors the state of charge. Probably it’ll briefly try to charge, realize there’s a glitch in the matrix, and reset current state of charge to reflect actual status. After that regular charging patterns will resume.
10-15-2020, 06:25 AM | #7 |
417
Rep 919
Thanks, Chief...that's good to know. I charge mine regularly, especially now with covid around.
10-15-2020, 06:34 AM | #8 | |
277
Rep 833
Drives: BMW F36, E36, E93
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
10-15-2020, 07:33 AM | #9 |
135
Rep 457
Yeap, that's the plan!
10-15-2020, 12:06 PM | #10 |
772
Rep 1,502
If you charge via the underhood posts, then the IBS (intelligent battery sensor) is able to monitor the charging current and all’s good. It’s only if you bypass the sensor by charging the battery directly via the battery posts that the sensor gets out of sync. But as I mentioned that’s only temporary until you start driving.
jackstrath658.50 |
