10-08-2020, 08:54 AM | #1 |
390
Rep 454
Winter Tire choice for 440I Xdrive Coupe
winter is about to hit so I'm looking to get a set of winter tires and rims and would like to get some suggestions.
I currently have 19 staggered 225 front 255 back OEM set up, and I want to go to 18 225 square for winter set, will that off set anything? Any suggestion on rims and tires? I'm looking at Bridgestone Blizzak WS90 suggested by friends, will cheap rim hold up during winter? Also is TPMS required for new rims or can I just swapping them in and out from my OEM one? Last edited by Alvin Mpower; 10-08-2020 at 09:39 AM.. |
10-08-2020, 09:25 AM | #2 |
8245
Rep 16,088
https://f30.bimmerpost.com/forums/fo...play.php?f=423
FWIW 17s are best for winter rims/tires. The higher sidewall greatly reduces the risk of pothole damage to both the wheels and tires. |
10-08-2020, 03:14 PM | #3 |
157
Rep 425
I run a similar staggered setup except on the stock 18s and run square 17s for winter. I bought rims off Ebay. Rims dont matter much except for fit, obviously. Pay attention to offset which I learned about the wrong way after I bought my first set.
Blizzaks, for the price, are completely overrated, IMO. Any brand name will perform perfectly. No one will mount your rims and tires without TPMS. Ebay again for this! And they dont actually have to work, they just have to be included on the install. |
10-08-2020, 11:17 PM | #4 |
1310
Rep 883
18x8s would fit your 225 square setup nicely. A winter-resistant finish helps, imo.
My guess is 17s will likely have issues clearing your big brakes. |
10-09-2020, 05:45 AM | #5 |
804
Rep 535
I’m running 225/18 square setup with NOKIAN HAKKAPELIITTA R3s.
The R3s are also available in run flats if you so desire.
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey Previous: 2016 328 xDrive Alpine White |
10-10-2020, 08:54 AM | #7 |
569
Rep 611
It depends on what kind of winter conditions are you preparing for. Cold? Snow? Ice? Rain? Dry?
Spent one winter (mostly dry and wet here) on 18" 225's squared and they don't provide enough traction for my taste. However, if you are facing lot of snow, this setup works very well. The tire choice again depends on the conditions. The currently best rated high performance winter tires are possibly Goodyear UltraGrip Performance+, Michelin Pilot Alpin 5, Continental WinterContact TS860P or Vredestein Wintrac Pro. Again, if you are regularly having lot of snow, you might be interested in snow-/ice-oriented tires as Hakkapeliitta (that are very compromised especially in dry conditions and higher temps). |
alohasurftoad3081.50 |
10-10-2020, 03:32 PM | #8 | |
Rep 23
Most of what I've been looking at has offsets in the 35-47 range. Shooting for an 18 inch rim to clear my brakes. Have the blue Msport ones |
10-10-2020, 09:44 PM | #9 |
47
Rep 99
I run Pirelli Sottozero 3's on mine during the winter in upstate NY (tons and tons of snow) and they were excellent. I never felt like I wasn't in control or like I'd get stuck. This is in a 428GC xdrive.
10-11-2020, 08:56 AM | #10 | |
157
Rep 425
Your offset range sounds right, IMO. |
10-11-2020, 11:34 AM | #11 |
188
Rep 424
First winter with rwd here I stocked up with sottozero 3s. Wheels are 19s which I know isn't ideal for winter but I love the look. Time to buy some mudflaps
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
10-13-2020, 08:24 AM | #12 |
391
Rep 849
Drives: BMW 435i
RWD 435 here and I'll cast another vote for the Sottozero 3's. It's a great tire that works well in a wide range of weather conditions.
I'm running them on a square 18" set up. My M Sport brakes wouldn't allow me to go any smaller.
Stop by and check out my blog: The Car Geek
10-13-2020, 03:25 PM | #13 | |
569
Rep 611
My experience is similar, if not worse. Just saying. |
10-13-2020, 03:59 PM | #14 | |
157
Rep 425
I suppose we all get sucked into the idea that since we love and drive performance machines, nothing but "performance" gear belongs on these cars. my .02 |
10-13-2020, 04:33 PM | #15 |
55
Rep 77
For applications that are more mixed conditions and not primarily snow/ice, Nokian WRG4 tires are worth a look. They're in the "all-weather" category between all-season and full-on winter tires. They work great as winter tires in California where I spend most time on dry/wet/relatively warm roads (winters wouldn't make sense) but then offer good grip on snow/ice when I make a trip to the Sierra (way better than any all-season I've driven in snow).
F31 328i xDrive, EBII
10-13-2020, 05:00 PM | #16 |
806
Rep 1,906
ktw: do those Nokian carry a tread wear rating?
I drive X3, just moved to Gardnerville, NV...I am very close to Tahoe and will be up there a lot in winter...maybe good pick for year round use? Last edited by Wgosma; 10-13-2020 at 05:17 PM.. |
10-13-2020, 06:03 PM | #17 | ||
391
Rep 849
Drives: BMW 435i
A more "serious" snow tire like the Blizzaks would not hold up as well in the warmer temperatures or endless miles on dry roads for weeks/months on end. Where I'm at it's too cold and just a bit too snowy for an all season tire, but too warm and not snowy enough for the softer deep snow snow tires. The performance tires like the Sottozero's work perfectly in these conditions.
10-13-2020, 11:32 PM | #18 | |
55
Rep 77
But I have to say I've been quite happy with the tires. Not the quietest ride but acceptable and dry performance on par with typical all seasons. In the snow they have always impressed. I'm sure a dedicated winter is a step up, but the WRGs are way ahead of most all seasons. Certainly have seen some cars in the rearview spin out on Carson Pass while I was just fine! |
Wgosma806.00 |
10-14-2020, 08:35 AM | #19 | ||||
806
Rep 1,906
I had Blizzacks in old E36 sedan when I lived in Idaho so I know a dedicated winter tire is superior to AS. The Nokian all weather sounds promising. |
10-14-2020, 08:48 AM | #20 | |
157
Rep 425
10-19-2020, 02:56 PM | #21 |
390
Rep 454
Hey guys, I just find a set of new Rim and Tire from someone of facebook marketplace, he is selling his brand new m340i 19in rims and tires, less than 100 miles on them, will this fit my 440i? The rim looks exactly the same as my current rims.
10-19-2020, 03:01 PM | #22 |
157
Rep 425
depends on tire size
