10-05-2020, 09:05 PM | #1 |
Rep 15
Rear seat climate control
I am still trying to get used to my X3MC and the BMW infotainment system. One thing I can't figure out is how / if you can control the rear climate control (temperature / fan speed) from the front?
I tried to search the forum history, but I couldn't find anything on this. Thanks in advance. |
10-05-2020, 09:23 PM | #2 |
53
Rep 102
Short answer: no.
The HVAC display in front is a dual zone one - and even retrofitting the tri/quad zone one from the G30, as some have done will not allow you to control the rear. Edited to add: In the HVAC display there is a "Menu" button, which does allow for certain presets to happen. Last edited by Anders R; 10-06-2020 at 01:55 AM.. |
10-06-2020, 12:25 AM | #4 |
Rep 18
I would assume when you push the "sync" button both the rears and front climate control sync up?
—2020 X3MC — Black Sapphire
Previous: 2018 X6M Black Fire Edition//2020 M340//2018 BMW 340//2018 X3 M40//2018 Audi S4//2016 Porsche Macan S//2017 X5//2015 IS350//2014 Audi A4//2015 Jetta TDI//2008 FX35//2007 G35//2007 BMW 335i//2005 TL//2008 Civic//2001 BMW 328CI//1999 BMW 323i |
10-06-2020, 07:28 AM | #5 |
164
Rep 285
Same, I assumed sync would as well. I’d like to completely disable all the rear buttons, however. Depending on which of my kids gets stuck with the middle seat, they have spitefully been activating the seat warmers of the others.
10-06-2020, 09:00 AM | #6 |
Barge driver
8656
Rep 12,425
I believe sync gives you that option it did on the 4 zone I had on my 7 series, so you can adjust the rear by using sync then if you want to change just the front disable sync.
730d/Z4C
10-06-2020, 09:35 AM | #7 |
139
Rep 192
Okay, that's funny!
2021 Cayenne GTS * 2021 AMG GLE 63
2019 911 Targa 4 GTS, Carrara White Metallic 2008 911 Turbo Cab, Speed Yellow 1997 911 Targa, Zenith Blue 2017 GT3-RS Lava Orange (LEGO) |
floating.spirit1017.00 |
08-23-2022, 10:46 PM | #8 | |
Rep 8
In my 2022 X4 I go to: -Car -Settings -Climate control -Hearing/ventilation -.Second row of seats Hope this helps |
08-24-2022, 01:50 AM | #9 |
150
Rep 242
Assume this post was initially made for the pre lci, which you cannot control the back seats
On the Lci you now can control the climate and the rear heated seats from the front. Now though unfortunately they have removed the sync button from the dash but it can be done in the menus |
