10-04-2020, 11:32 AM | #1 |
4551
Rep 4,659
Alcon rotors for 2NH
FYI, Alcon is willing to create a bmw hat to fit there 400mm and 380mm rotor options that would fit the 2NH option. I'm inquiring about what a full set of rotors would cost and if partially or fully floating. Since I'm sticking with steel I Would be looking for saving a few extra pounds if possible. My googling suggests about 6lb lighter on front and 3lbs on rear. Never going to be CCB savings, but every bit helps.
10-04-2020, 01:03 PM | #2 |
4551
Rep 4,659
Anyone have the hat dimensions that would be necessary? I'm guessing they would need lug pattern dimension and hat depth to appropriately position rotor in stock caliper.
10-04-2020, 04:56 PM | #3 | |
429
Rep 433
Please keep us posted on any developments |
10-04-2020, 04:59 PM | #4 | |
429
Rep 433
The lug pattern is 5x120mm The thread pitch is M14x1.25mm The center bore is 72.56mm |
10-04-2020, 05:59 PM | #6 |
4551
Rep 4,659
Any chance you can grab me a higher resolution image? I'm sure this is the type of data they are after. I told them they already make a hat for the m2 CS racing, but unsure if it's the stock position since that also use an aftermarket front caliper.
10-05-2020, 12:41 PM | #9 |
4551
Rep 4,659
Alternately
https://www.girodisc.com/Girodisc-Fr...rs_p_6855.html I'm sure they can put together some rears.
