09-30-2020, 08:43 AM | #1 |
55
Rep 114
Tire pressure Recomended
I got the warning message yesterday. It said my tire pressure are low. So I checked them all and they were all to the spec per the sticker. But the message show 42psi recommended for front and 52psi for rear. But tires MAX ARE 50psi.
So I'm totally confused |
09-30-2020, 10:42 AM | #2 | |
The Centurion
137
Rep 451
Alternatively the pressure recommendations does go higher after a short drive of more than 2 miles. So if you do 52 it must be after a drive. This will go down once the vehicle cools down. Assuming you have the correct tires settings in iDrive.
From the East to the West through the rest of the World
09-30-2020, 10:55 AM | #3 |
112
Rep 131
I had a similar issue, door jamb indicated 32 / 38, tires had 41 in them, lowered them to the 32 / 38, and got a warning on all 4 tires. Went into the tire settings in iDrive, and it was set up for 22" summer tires, changed it to 21" all season which is what is on the car, and no more warning.
"Horsepower is a terrible thing to waste."
MystroX56289.50 |
09-30-2020, 11:20 AM | #4 | |
6290
Rep 5,324
09-30-2020, 12:29 PM | #5 | |
112
Rep 131
10-02-2020, 06:36 PM | #8 | |
111
Rep 376
There is setting in the iDrive asking about what speeds do you drive with, if you set under 100MPh/h then you get similar to the sticker, however if you set above 100MPh then this will start suggesting much higher pressures Make sure it shows the below 100MPh and all will be as you expect 🤩 Unfortunately dealers have no clue about it... |
10-02-2020, 10:36 PM | #9 | |
55
Rep 114
yes, I did changed to below 100MPH now |
10-03-2020, 06:59 AM | #10 | |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
The TPMS in the X7 is "smarter" now as the recommended tire pressure it tells you takes into account the real time tire temperature inside the tire - which of course changes (gets warmer) as you drive, and causes pressure to increase. The system goes further by adjusting the pressure recommendation based on the type of tire installed on the X7, summer vs all-season/winter tires. This is helpful so that if you have a low tire pressure situation while out driving, you can accurately re-adjust your tire pressure without the need to wait until your tires are cold again - which will only happen after an extended period of time with your car sitting (like overnight). That said, it is still better to check/adjust your tire pressure when cold if possible for the most accurate tire pressure setting and performance. Keep in mind that the "max" tire pressure that you see stamped on the side of the tire is actually the "max cold" inflation pressure. So when the tires are cold, you should not go higher than that pressure stamped on the side of the tire. It is not uncommon that under normal driving conditions, the tire pressure can actually go higher than the stamped pressure on the side of the tire, just due to the normal heat generated by driving that causes an increase in pressure.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
10-03-2020, 07:15 PM | #12 |
///M SubDriver
1837
Rep 2,784
No. Minor adjustments in tire pressure do not require resetting the TPMS in iDrive.
10-03-2020, 07:53 PM | #13 |
217
Rep 814
Today for the first time I received a low tire pressure warning. The temperatures have dipped to 48 degrees at night so I assumed this was the reason. When I checked the tire setting it was set to winter. I have summer tires installed. I have never checked this or made any adjustments in the past. I set it to summer and selected the tire displayed which was the right one (stock conti 22" run flats). Then the message below displayed. I will put some air in tomorrow.
10-03-2020, 08:47 PM | #14 |
217
Rep 814
The other thing I would add;
Let's assume this was set to summer from the factory. There are only two things that I did that could potentially impact this setting, an iDrive OTA software update or coding via BimmerCode. Can others who have done a software updates or coding via BimmerCode check this to see if the summer/winter is set incorrectly? |
10-05-2020, 10:58 AM | #15 | |
The Centurion
137
Rep 451
On a side note. I came to know recently (which Is strange for me) that dealers tend to backup system before update. In my opinion and experience this retains the issues if any are existing.
