09-28-2020, 06:02 PM | #1 |
Freude am Fahren
454
Rep 359
Drives: G26 i4 M50, F11 M550d, E70 X5
BMW F20 LCI auto/returning column stalks retrofit
For me, the new mechanical column stalks (turn signals and windscreen wiper) are really annoying. The older F20s have stalks that returns to center automatically. Have successfully retrofitted newer type of column stalks from F15 on an F20 M140i. It looks similar to the mechanical versions, except of the auto windscreen wiper button and off course as they returns to 0-position when operating. It feels so premium and more modern now!
2024 G26 i4 M50 Individual
2015 F11 M550d Individual 2012 E70 X5 30d |
10-05-2020, 03:58 PM | #2 |
142
Rep 301
very cool mod! how much did it cost you? also have a 2018 f20 m140, might be interested to do this
"We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art" - Chris Bangle
"If it depreciates, lease it. If it appreciates, buy it." |
10-05-2020, 04:10 PM | #3 |
Freude am Fahren
454
Rep 359
Yes, it is! It costed around 120 USD, for an F15 steering column switch with coil spring and an new button for steering wheel heating. I coded it with bimmercode.
JovanUK141.50 |
02-07-2022, 04:23 PM | #4 |
Rep 6
Hello!
I have F20 LCI2 and hate mechanical column stalks. Can you help me how to code through bimmercode new column stalks which returns to 0-position when operating (i also bought stalks from F15). |
02-08-2022, 02:48 PM | #5 |
Freude am Fahren
454
Rep 359
Yes, off course. If you have steering wheel heating, you also ned to change the heat button from an 2AT/F15. Just send PM.
02-09-2022, 05:40 AM | #6 |
Rep 6
Thanks a lot, but i can`t see a private message folder probably because i`m new member and i need to write a couple of posts before. When i get access to private message system i will ask you to help me.
02-15-2022, 11:55 AM | #7 |
Freude am Fahren
454
Rep 359
I sent you an PM.
08-14-2023, 07:42 AM | #8 |
Rep 22
Drives: 2018 BMW 340i
Bimmercode
I retrofitted my 2018 F30 with the old model stalks, but the far press indicator does not work. It stays on as long I am pushing it. The lane change works (3 blinks) and so does the wiper. Is there any coding required to keep the far press working?
08-26-2023, 07:05 AM | #9 |
572
Rep 2,048
Did you code the steering column variant?
phoenixorion0.00 |
08-26-2023, 07:47 AM | #10 |
Rep 22
No. I don’t know the variant to code.
08-26-2023, 08:30 AM | #11 |
Rep 22
Also I have the bimmercode app.
08-26-2023, 08:59 AM | #12 |
572
Rep 2,048
LIN_VARIANTE_SZL
Which option does it show? The lci and pre-lci steering with self returning stalks have _R_ different. |
phoenixorion0.00 |
08-29-2023, 08:09 AM | #13 |
Rep 22
Sorry for not responding. I was traveling I’ll update you by end of today.
09-03-2023, 12:48 PM | #14 |
Rep 22
I have szl_us_r_aic selected
09-04-2023, 07:25 AM | #16 |
Rep 22
Ok. I’ll try and let you know. Thank you.
09-04-2023, 07:49 AM | #17 |
Rep 22
I do not have dzl_us_aic in the available list. Should I add that as a custom value?
09-04-2023, 07:51 AM | #18 |
Rep 22
I mean szl_us_aic
09-04-2023, 08:31 AM | #19 |
Rep 22
One thing I noticed: when I select the not active option in Lin_variante_szl, the indicator still functions as long as I push/pull the stalk. It goes off when I release it. I tried with many options but the behavior is the same. The lane change blinks 3 times but after the threshold it only blinks as long as I hold the stalk in the position.
09-04-2023, 09:01 AM | #21 |
Rep 22
The part is LZ 9 351 140-02 10112143-02. All the options with szl_us has r. For eg szl_us_r_aic.
09-04-2023, 09:03 AM | #22 |
Rep 22
The options are szl_us_r, _4Band, aic, aic_4Band, aic_4Band_fla, aic_fla etc. I tried all the options but the functionality is the same.
