BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum Air Suspension “Level change not available” Issue
      09-27-2020, 12:54 AM   #1
kbl888888
Drives: 2019 BMW X7 50i
After i intalled the “RG Sport Lowering Link” , then all suspension adjustability is restricted, the car screen shown“Level change not available”, Does anyone know how to solve this problem? Do I need to send it to the dealer?
r33_RGSport12971.00
      09-27-2020, 01:25 AM   #2
jsmonet
Drives: 2020 x7 m50i
You're probably better off just hitting up Ben directly r33_RGSport for a first look/sanity check.
2020 bmw xHippo, v8tt edition
r33_RGSport12971.00
      09-27-2020, 04:03 AM   #3
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Yeah, the dealer will scrutinize you very hard on this one (for any potential warranty claim) as this issue can clearly be attributed to an aftermarket, non-BMW part and install. If anything though, I suspect the system might just need to be reset, like when you remove/rotate the wheels/tires.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      09-27-2020, 04:25 PM   #4
Andyx5
36
Drives: bmw x5 3.0d
I got this error on my x5. When you hit the up and down lever this should be a quick flick. If you hold the switch as it goes down or up it put the car into a service mode which prevents the car suspension moving when changing a tyre. Not sure if this is your issue but had this problem when I first got the car.
      09-27-2020, 06:13 PM   #5
Luminor513
Luminor513's Avatar
1243
Drives: 2020 G07 x40i BSM/Blk Merino
Drive around for a few minutes in the car and the air suspension will auto correct itself. Same thing happened with my car after installing the lowering links, after couple min driving the system corrected itself.
2022 Audi E-tron S Mythos Blk/Blk Valcona
      09-27-2020, 11:02 PM   #6
kbl888888
yes, I drove for a while and was back to normal, but i had a problem again with the right side is higher than the left side. then i tried switching to any mode that was high on the right and low on the left. Do you know how to solve this problem?
      09-27-2020, 11:04 PM   #7
kbl888888
      09-28-2020, 06:31 AM   #8
Luminor513
Luminor513's Avatar
1243
Has everything resolved itself or is the right side still not sitting at same height as left side?
      09-29-2020, 05:53 PM   #9
kbl888888
All resolved,ground uneven.
Appreciate 2
Luminor5131243.00
r33_RGSport12971.00
      09-29-2020, 10:47 PM   #10
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Glad you got it resolved.
Sorry just saw the post.
Side note: Anytime you are going to lift the car, you have to disable the air suspension.
If I remember correctly, you have to toggle up the suspension height setting for 3 seconds then let go.
The indicator light should turned off.
Once you are done, do the same step and the light will turn back on and suspension fully functional.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
xbimmers
