09-25-2020, 10:40 AM | #1 |
48
Rep 206
Harmon Kardon 3.5". S aftermarket
I wanted to get opinions or recommendations. My car does have the Harmon Kardon audio set. I have blown my 3.5" front speakers and I do have warranty on the system. They can be replaced but this also gives me the option of going aftermarket.
Compared to the speakers I currently have, would it make sense to go different? A heads up, i do NOT want to spent insane money. Im not blaring the music, i just expected more lower end from what i have. I was basing adjusting the eq. Advice, opinions and recommendations qre greatly appreciated. Thanks
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
09-25-2020, 11:50 AM | #2 |
8283
Rep 16,151
They're nominal 4 inch drivers. There are aftermarket drivers that work better than stock, but only if you want to spend major bucks, and the improvement is barely measurable, let alone audible. As for the low end, that all comes from the under seat woofers, not the doors. There's room for improvement there, but only if you upgrade the amp. Here's one example: https://f30.bimmerpost.com/forums/sh....php?t=1730058
09-25-2020, 02:13 PM | #3 | |
48
Rep 206
That being said, are amps other than the amp you suggested available? Are there other plug and play options? I truthfully would prefer to spend $700 on my engine than my system. I just want to "clean up" the sound a bit.
09-25-2020, 05:01 PM | #4 |
8283
Rep 16,151
I didn't recommend any amps, I just linked someone else's experience. Where plug and play for BMW is concerned there's very little out there, and none are at a bargain basement price.
09-25-2020, 05:20 PM | #5 | |
569
Rep 611
The market is full of aftermarket upgrades and most of them are even PnP - the same connectors, mounting holes and resistance. While they differ in sound, quality and cost, you can be sure that speakers from reputable brands as Audison, Eton, Focal, Gladen, Match, MTX, Rockford Fosgate, etc. do sound much better than the poor HK ones. Another option is retrofitting of higher-class speakers from other BMW-group models - all except some Mini are fully compatible, no matter if it's Bang&Olufsen, Bowers&Wilkins or even RR Bespoke ; you just need to select the proper speakers. In general, all these speakers will improve the clarity, the tweeters will be significantly more exact and the mids will cover wider frequency range with more mid-bass (something what's critically lacking in stock speakers). How much better, it depends on your choice of speakers and your ears As you are interested mostly in bass, you need to consider upgrading the underseat woofers. There you have two choices, additional amplification or just replacing the woofers. While many people are successfully running the (4-ohm) aftermarket woofers with stock HK amp, the (never solved) mystery lies in fact, that HK woofers are 7-ohms and nobody knows the specs of the amp. At least in one case, the thermal protection switching off the amp due to overheating had been reported. When considering the upgrade and its cost, the least I would suggest is upgrading the front door speakers (2 tweeters, 2 mids), the dash speakers (1 tweeter, 1 mid) and the (2) underseat woofers. Indeed, you can upgrade gradually and - as bass is your main interest - begin with the woofers; but count with the risk you'll find the stock speakers to be even worse after the woofer upgrade. Or you'll be satisfied, who knows To "clean-up" the sound, in my opinion upgrading the mids is the most important. |
09-25-2020, 11:35 PM | #6 | ||
48
Rep 206
I understand replacing the factory amp will help very much...i just wanted to see if changing the mids and highs would theoretically be sn upgrade from the HK system i have without changing the amp?
09-25-2020, 11:49 PM | #7 | |
48
Rep 206
So basically, bring the car in and have them replace the speakers....? There would be no advantage to going aftermarket without changing the amp?
09-26-2020, 08:24 AM | #8 |
8283
Rep 16,151
The weakest point of the system is the electronics, so that's where money is best spent. There's nothing wrong with the speakers. Harmon isn't exactly a newcomer to loudspeaker technology. They own JBL, Infinity, Revel, Mark Levinson, Bang and Olufson and many others.
I've seen lots of claims for aftermarket speakers being better. None yet have been accompanied by the measured data that acoustical engineers like myself use to make objective comparisons between different drivers. Advertising claims are not technical documents. Johnung replaced his under seats with Earthquake SWS woofers, which will go both lower and louder than the stock woofers, but only when provided with adequate power. He did so with a separate amp for just the woofers, giving the Earthquakes enough power to function as well as possible. It also cleaned up the sound from the rest of his stock speakers. By putting the low frequency power load on the auxiliary amp, which accounts for some 70% of the total system power requirement, the stock H-K amp runs with far less distortion, making the stock in-door speakers sound better. |
09-26-2020, 12:22 PM | #9 | |||||
569
Rep 611
Saying the woofers accounts for 70% of the total system power requirement is ridiculous. I am feeding my woofers from the HK amp and can tell you that: - the amp has enough power to drive the woofers. In fact, the combination has huge reserves, as it can achieve bass and loudness nobody can bear, - I upgraded the speakers and woofers separately and while your theory of reduced amp load and less distortion has indeed a good base, it cannot be recognized by my ear in real life at all, - I would suggest you to perform a comparison (both subjective and measured) of different woofers. For instance, to me my woofers sound significantly better compared to separately amplified Earthquakes I have listened to. Indeed, the SWS produces tight bass, but they do not sound as good as some others to me and certainly do not blend well with the other speakers I have listened to, - The Earthquakes mentioned by you all the time are not the Holy Grail of underseat woofers according to many. I would consider twice to recommend them in a such way, when several reputable retailers and installers in Europe already stopped recommending or even selling them, some mentioning high RMA rate, some: Quote:
pierreye212.00 |
09-26-2020, 08:32 PM | #10 | ||||||
77
Rep 95
True Car audio isn't about about the perfect arrivals. It's learning and trial and error. And I think speaker changes are an amazing first start. |
J555568.50 |
09-26-2020, 09:56 PM | #11 |
8283
Rep 16,151
I did my learning. I designed my first speaker in 1969, have a Masters in Acoustical Engineering and own a loudspeaker design company. Not counting the designs I offer to the DIY set there are currently over a dozen loudspeakers that I designed on the market from various companies. As for trial and error, that method went the way of the Dodo forty years ago. Audio is a science, and the science always works, whether you understand it or not. And pardon me for not responding line by line to posts by those who don't understand the science. I have no inclination to waste a minute of my time on those who'd rather argue than learn.
09-26-2020, 10:41 PM | #12 | |
77
Rep 95
No one asked for your CV. Please don't respond. |
J555568.50 |
09-27-2020, 09:22 AM | #13 |
421
Rep 843
Yes, this says it all....the guy with 32 posts tells the professional audio engineer with 9660 posts...and I’m being kind to not even look at the reputation count...to “please don’t respond”.
I’d take that advice. Arguing with the ignorant is like spitting in the wind. |
09-27-2020, 12:16 PM | #14 | |
77
Rep 95
Son, you really need to stop living your life according to to the internet. While you think post count and reputation points will add weight to the argument, I assure you it doesn't. Why are you in an automotive forum looking for audio intelligence? Now, I'm new, really new to the internet. So new in fact, I discovered the internet yesterday, and audio the day before that. Feel better? Dump the insults, this isn't a contest. My initial argument that you didn't address remains. If the amplifier stays the same and you change speakers, can you hear a difference that will allow you to discern your preferred speaker? |
J555568.50 |
09-27-2020, 04:25 PM | #15 | ||
569
Rep 611
Personally, I did learn from people here tons of knowledge and that indeed includes Bill. I am very thankful for that, they helped me make my own opinions, no matter, what it is. |
09-27-2020, 04:38 PM | #16 | |||
77
Rep 95
