Bimmerpost
4 Series
Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications After bench unlock and tune I can't use remote start
      09-25-2020, 09:03 AM   #1
Obitelb
Obitelb's Avatar
15
Drives: M340
I have catless downpipe and after tune I can't remote start. anyone have the same issue?
      09-25-2020, 10:14 AM   #2
chenry
Drives: BMWs
This is a known issue after most (if not all flash tunes) - if you flashed with Mission Performance they have a work-around for you.
Who did you flash with? if MP Im guessing Alex wasn't aware you had remote start and therefore didn't enable it for you
ps- the work around is not the most elegant solution in that it requires you to leave your key card in the area where the remote charging tray is - otherwise it works perfectly
      09-25-2020, 01:14 PM   #3
Obitelb
Obitelb's Avatar
15
Drives: M340
I have ecutek tune from visconti.. After that remote start gone
      09-25-2020, 08:07 PM   #4
Patgilm
181
Drives: GT-R, X7 M50i, M340
Oh wow I didn’t realize Ecutek was an option. That is what I was planning to use to tune my GTR if I ever get around to it and may even use Visconti.
      09-25-2020, 08:10 PM   #5
Voodoo_G80
Drives: G
Wow! How much did you pay for the tune and what options did you go with?
      09-26-2020, 12:00 AM   #6
chenry
Drives: BMWs
well you're working with some quality people - I'm sure they can figure something out. Keep us posted relative to your solution :-)
      09-26-2020, 05:11 PM   #7
Patgilm
181
So just curious, did you try putting your key card in the wireless charger area? As chenry mentioned, that is what I had to do after my tune.
      09-27-2020, 03:10 PM   #8
Alexey
31
Drives: M340
What time 0-60, 60-130, 1/4?
      09-28-2020, 12:55 PM   #9
Rocket455
Grumpysaurus Rex
Rocket455's Avatar
Drives: 2022 M550i
1972 Firechicken  [0.00]
1969 Toronado  [0.00]
1970 Camaro  [0.00]
CarBahn stage 1 flash here; same exact issue: after install, remote start (both, via app as well as remote) no longer functioning. CarBahn is aware that this is a known problem, no solutions yet.
“Science has made us gods even before we are worthy of being men.”
      10-05-2020, 05:02 AM   #10
Obitelb
Obitelb's Avatar
15
Drives: M340
Sorry for respond ecutek cost 1k. And tune 600.. I went with stage 2
Definitely feels better then stock
      10-05-2020, 08:15 AM   #11
Obitelb
Obitelb's Avatar
15
Drives: M340
I didn't do it. Yet.. But you have to program key first right?
      10-05-2020, 08:17 AM   #12
Obitelb
Obitelb's Avatar
15
Drives: M340
I just bought dragy.. Let you know later
      10-05-2020, 10:33 AM   #13
john!smith
john!smith's Avatar
230
Drives: M340i XDrive
for comparison reasons…
MHD stage II, Catless Downpipe and a Chargepipe
0-60 mph 3.38 sec. @ -0,23% slope
60-120 mph 7.7 sec @ -0,32% slope
      10-05-2020, 12:43 PM   #14
Obitelb
Obitelb's Avatar
15
Drives: M340
Custom tune?
      10-05-2020, 01:51 PM   #15
john!smith
john!smith's Avatar
230
Custom tune?
kind of… I make my vehicle available for development
so at the Moment, i would say it is a custom tune which is going to be available for everyone later
and i can tell you… there are still reserves. specially for the us costumers. i have a EU model with a particle filter which is restrictive
      10-05-2020, 08:13 PM   #16
Patgilm
181
I didn’t program it. It was in the sleeve of my owners manual and I just took it out and put in on the wireless charger and now the remote start works.
      10-05-2020, 08:18 PM   #17
Obitelb
Obitelb's Avatar
15
Drives: M340
I didn't program it. It was in the sleeve of my owners manual and I just took it out and put in on the wireless charger and now the remote start works.
Do you have tune or bench unlock?
      10-05-2020, 08:48 PM   #18
chenry
Drives: BMWs
I did the same however this only works if you have a Mission Performance flash tune
Alex built this functionality and makes it available to his customers running on his platform
Presently all other tunes will kill your remote start capability and there is not a solution as of yet (by anyone other than MP) to fix the issue.
Last edited by chenry; 10-06-2020 at 12:07 AM.. Reason: typo (I'm sure there are others I missed HA)
      10-05-2020, 11:43 PM   #19
Patgilm
181
I have software version 3/2020 so I had to send my ECU in to Mission Performance to unlock it on the bench.
      11-03-2020, 02:31 PM   #20
Lonmon
60
Drives: 2020 BMW M340i x
Any update on fix for the remote start being disabled after a tune? Just had a stage 2 done on mine by a local tuner and of course the remote start does not work anymore. Getting cold in the PA/MD area. I sure would like to get it working again soon. I wonder what the work around is that Mission is using or if they can offer the workaround only for someone who already has a tune? I can't seem to find any good info on why or how it gets disabled when merely tuning the engine ecu. I have a key card and wouldn't mind the leave it in the tray trick if I could get it coded for that. Anyone have any info or advice?
2020 M340i Xdrive Portimao
AA catless downpipe (offroad only of course)
BMS intake and Inlet tube
H&R Springs
MHD Stage 2 E40
      02-24-2022, 03:39 AM   #21
retart13
Drives: M340i Xdrive
Also wondering if this is possible?
      12-08-2022, 03:47 PM   #22
b58.fazil
65
Drives: 2020 BMW M340i xDrive Alpine W
MHD now has a remote start fix for gen 2 b58s
g20
